Sponsored by: Innova
Stereo amplifier not working (Bose)
Old Feb 12, 2022 | 03:20 PM
Marcus_1970's Avatar
Marcus_1970
5th Gear
Default Stereo amplifier not working (Bose)
Hello and thanks in advance for any help! Just bought a C5 zo6 2003 and stereo volume level is barely audible. I have checked passenger side fuses 24 and 28 both are good. Also swapped the Bose relay with the rear defrost of same type no luck. I am ready to just replace the unit but not sure if the issue is with the stereo itself or Bose amplifier/controller. Any help is much appreciated
thanks again!
Old Feb 12, 2022 | 05:01 PM
VinceC5's Avatar
VinceC5
The top door and rear speakers are powered directly from the headunit. The door subs are powered by dedicated amps within each speaker. If there is no sound and all speakers and wiring is good, then I suspect the head unit.
Old Feb 12, 2022 | 07:06 PM
Marcus_1970
5th Gear
Thanks Vince this definitely helps! I can here sound throughout its just really faint even at full volume. Guess I’ll be stereo shopping soon! Any suggestions for an easy drop-in single din system? Thanks again!
Old Feb 12, 2022 | 09:25 PM
VinceC5's Avatar
VinceC5
Not much of a selection for single din, but this one has bluetooth and phone controls.
Kenwood btc278u
There are also some with a flip screen or even those single din with a 10" screen.
You can also go with a double din and get the new dash kit offered by several vendors.
Old Feb 20, 2022 | 06:31 PM
Marcus_1970
5th Gear
Default Is there a fuse in the head unit ?
Does anyone know if there is a replaceable fuse in the head unit itself?
thanks!
Marcus
To Stereo amplifier not working (Bose)
