Sponsored by: Innova
"pre wired" for factory CD changer????
Old Dec 29, 2002 | 07:32 PM
Mike Mercury's Avatar
Mike Mercury
Default "pre wired" for factory CD changer????
I've seen many comments made thet the newer C5's already are pre-wired (or partially so) for the factory CD changer... even on the C5's that never had the changer.
What exactly does this (pre-wired) represent?
[Modified by Mike Mercury, 7:33 PM 12/29/2002]
Old Dec 30, 2002 | 04:25 PM
ersatz928's Avatar
ersatz928
Default Re: "pre wired" for factory CD changer???? (Mike Mercury)
Prewired means that there are connectors in the passenger side footwell. You stil have to buy a $90 cable from GM, which then goes to the back of the car. "Prewired" my azzz!!
Old Dec 30, 2002 | 07:30 PM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
Default Re: "pre wired" for factory CD changer???? (ersatz928)
Is the connecter that you mention in the footwell area a C-net type connecter?
and were is it exactly if you could zoom me in closer, i have a Clarion 6 disc, w/ that connecter thanks :chevy
Old Dec 30, 2002 | 07:40 PM
Mike Mercury
Default Re: "pre wired" for factory CD changer???? (Rob 99)
ersatz928
thanks for the info. BTW, you can get the factory CD changer harness (that goes to the back of the coupe) from Fichtner for $47.
There are two CD changer related connectors in the passenger footwell area (near the fusebox). One is a 4 pin (I think that is the line level audio inputs to the head unit). The other connector is 3 pin and contains ground, 12v, and the serial data line.
To "pre wired" for factory CD changer????
