Sponsored by: Innova
Stereo wiring check, please
Old Mar 16, 2022 | 12:20 PM
ChemGirl's Avatar
ChemGirl
Default Stereo wiring check, please
I’m installing an Alpine ILX-W650 with a backup camera in my 2004 vette. Would someone please check my wiring before I start soldering? Most is very straightforward (yellow to yellow, red to red, blue to blue/white and black to black), but I want to make sure I’m getting the power source correct. I the loose wire from the PAC harness (next to the pencil) will tap into the yellow wire under the steering wheel. From what I understand, the 04 doesn’t have the option to tap on the passenger footwell.
Old Mar 16, 2022 | 01:06 PM
madsonp's Avatar
madsonp
Maybe @VinceC5 will jump in here, he has more experience with the C5's than I do. If you don't hear from him soon, you could probably shoot him a PM.
Old Mar 16, 2022 | 01:10 PM
Pb82 Ronin's Avatar
Pb82 Ronin
The PAC is a "T-harness" correct? So it just installs in between your HU and OE harness? So you'd be soldering the HU pigtail to the OEM harness. Those are the wires you got to get right...
Also, are you ONLY installing a HU? Or are you doing amps too?
Old Mar 17, 2022 | 10:28 AM
ChemGirl's Avatar
ChemGirl
It's a "t-harness". I was sent the wrong wires for the right side of the PAC unit, which is why there is nothing plugged into that side.
There's a red wire that doesn't run into the harness that hooks into the factory harness. I wanted to double check to make sure this is the wire that connects to the yellow wire under the steering wheel.
I'm just replacing the HU and adding a backup camera. Not touching amps, speakers or a sub right now.
Old Mar 17, 2022 | 10:38 AM
Pb82 Ronin's Avatar
Pb82 Ronin
That red wire is undoubtedly a power wire. I believe they leave it out so you can run it directly to where you need it. Just don't solder anything until you get the correct harness for the right side.
Old Mar 17, 2022 | 11:17 PM
VinceC5's Avatar
VinceC5
@ChemGirl replied to your PM.
Old Mar 18, 2022 | 12:33 AM
madsonp's Avatar
madsonp
Atta boy Vince, I knew you'd come through.
Old Mar 18, 2022 | 07:00 AM
Pb82 Ronin's Avatar
Pb82 Ronin
Damn Vince, was I that far off?
Old Mar 18, 2022 | 03:04 PM
VinceC5's Avatar
VinceC5
you're always way off, but let's not get into that right now.
The red wire is for Acc power in. It can go to any circuit that provides Acc power and has enough capacity to handle the extra current. The wiring under the steering wheel is a common source. Also you could tap into a circuit on the fuse box with an adapter like this... make sure its the right type... TAP
Old Mar 18, 2022 | 03:22 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Damn bro...shots fired. LOL! Let's not scare off the new girl...
Old Mar 19, 2022 | 09:13 AM
ChemGirl's Avatar
ChemGirl
Thanks to @VinceC5 I was able to get everything wired up and running yesterday. I grabbed power from the harness under the right side of the drivers knee panel. The PAC unit I was sent had the wrong harness for the subwoofer side, so I won’t be able to put everything back until the correct harness arrives.
Old Mar 19, 2022 | 04:14 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Yeah, Vince gets lucky every now and then.
Old Mar 19, 2022 | 05:43 PM
VinceC5's Avatar
VinceC5
@ChemGirl glad you got it done.
@Pb82 Ronin so many comebacks for this one, but I'll let it go since I took the first shot.
Old Mar 20, 2022 | 02:06 AM
madsonp's Avatar
madsonp
Good job Vince, I knew you'd be able to help her. And congratulations ChemGirl on your new system, looks good.
To Stereo wiring check, please
