Sponsored by: Innova
C5 Double Din Upgrade Completed
Old May 10, 2022 | 09:09 PM
rellz614's Avatar
rellz614
Default C5 Double Din Upgrade Completed
I decided the stock radio w/ fm transmitter wasn't going to cut it. I ended up w/ a Kenwood 4707S w/ backup camera. A couple of photos attached. All work done by Corvette Care in Columbus, Ohio. FYI, for the Kenwood system, if you get an error when trying to adjust the backup camera gridlines, you'll need to engage the parking break. Otherwise you'll get an error that says it can't be adjusted while driving - even if the car isn't running. The adapter unit / wiring harness to keep the Bose integration is something like ROEM VET1 - not sure of the exact make model but it's close. The USB for car play is routed inside of the centerr console / armrest, so it can be closed w/ the phone in it for a very clean look (unlike the photos below). Happy to answer any questions - very happy w/ the results.
Old May 11, 2022 | 10:08 AM
madsonp's Avatar
madsonp
Looks like it turned out nice, I'm sure you'll like it much more than the stock system.
Old May 12, 2022 | 08:22 AM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
Which replacement console did you go with, Metra or Vettenuts?
Old May 14, 2022 | 10:07 AM
jdmvette's Avatar
jdmvette
Night Owl for life
^ that'd be a metra
Old May 14, 2022 | 03:30 PM
Eshoremd's Avatar
Eshoremd
2023 C5 of the Year Finalist - Modified
I have the same bezel and do not like the open cup holder look.
If you push on the upper right corner does it flex? Mine does, the left upper right corner is solid.
I went with a sony and have yet to figure out how to use the carplay. Blurtooth works
Love my b/u camera!!!!!!
I'm going to have to get a woofer. The bass is very lacking.
To C5 Double Din Upgrade Completed
