Sponsored by: Innova
C7 vert custom subwoofer enclosure
Old Aug 14, 2022 | 12:50 PM
thebert's Avatar
thebert
Default C7 vert custom subwoofer enclosure
Anyone try to build a custom sub box in a c7 vert yet. If so can u show me pics
Old Aug 15, 2022 | 01:46 PM
madsonp's Avatar
madsonp
I build a custom box for my C6, vert, I don't know if it would work in a C7 though. It uses two Kicker 8" Solobarics.
Old Aug 15, 2022 | 02:53 PM
thebert's Avatar
thebert
Thats sharp, how did it sound..
Old Aug 15, 2022 | 03:13 PM
madsonp's Avatar
madsonp
Sounds real good, I'm running a Kicker amp https://www.kicker.com/CXA8001-800-W...-Subwoofer-Amp to power the sub, I mounted the amp behind the water fall in the place where the stock XM tuner was. I bought the 4 ohm speakers that I wired to 2 ohms, and at 2 ohms the amp puts out 600 watts, I had to remove the stock rear speakers (which I don't miss) and I'm still running the stock speakers and amp in the rest of the car, which I don't mind because the added bass from the sub makes the rest of the car sound really good. I'm also running a Pioneer AVIC 8200 NEX head unit that also was a major improvement in the sound.
Old Aug 15, 2022 | 05:40 PM
VinceC5's Avatar
VinceC5
cool box!
Old Sep 14, 2022 | 03:15 PM
Sean Dour's Avatar
Sean Dour
6th Gear
That is awesome work, do you happen to build a C7 regular sub-box or know the best route I can go...Need a box that will put out some serious thump before I start with the rest
Old Sep 14, 2022 | 04:15 PM
thebert's Avatar
thebert
i got one that takes 2 jl audio tw 13.5 shallow mount subs. Its loud as hell and u can still put ur top in it with issues
Old Sep 14, 2022 | 04:19 PM
thebert's Avatar
thebert
Old Sep 14, 2022 | 05:49 PM
madsonp's Avatar
madsonp
Thanks, I appreciate that. No, sorry, I have no experience with the C7's, I've been in discussion with another C7 owner on this forum who's interested in one of my boxes, but we need to look at dimensions and other issues to determine if it would even work. The problem is that I don't know anyone in Montana that has a C7 vert that I could even look at to see how much of a difference there is between a C6 and C7.
Old Sep 14, 2022 | 05:53 PM
thebert's Avatar
thebert
it is different, the airspace clearance is not the same. When i get home in a few days imma take measurements
Old Sep 14, 2022 | 05:55 PM
madsonp's Avatar
madsonp
Thanks, it'll be interesting to see what you show for measurements.
To C7 vert custom subwoofer enclosure
