Adding Bluetooth and an Auxiliary Input for C5?
. But seriously, it seems that a lot of the plug-and-play modules that were available years ago for these sorts of modifications are no longer available, and trying to make heads or tails of the various inscrutable offerings on Amazon leaves my eyes glazed over. I have the factory radio/CD player in my '02 Z06 (so no multi-disc changer) and I would like to keep it but add -if possible - bluetooth and some sort of auxiliary plug to be able to play other media.As for bluetooth, I know there are the cigarette lighter type devices that connect via a radio frequency, but my impression is the quality of sound is sketchy at best. Is there any sort of plug-and-play module that accomplishes this? My sense is that something hardwired would (at least theoretically) provide a better connection.
As for an auxiliary input, again I'm hoping to find something plug-and-play with some sort of wire input dongle that can be run out the side of the console or some such. I know about the thread where the guy installed an auxiliary jack input on the faceplate of his radio, but I'm unwilling to tackle that sort of project. My fingers are too fat and I doubt my hands would be steady enough to tackle something like that.
I DON'T want to switch to a Double Din head unit, and I don't really like how the single Dins look either. If you've done these replacements and are pleased with the outcome, that's great and I'm happy for you. BUT I just want to keep the factory set-up and possibly add these two features within the parameters I've attempted to describe. If that's not possible, so be it, and I'll survive. I'm also open to the idea of sending off the head unit to some business and having these modifications done by them, if such a place exists. Thanks in advance for any useful guidance !
Am I correct that you connected this device to where you would connect the factory multi-CD player? This connection would be by the foot of the passenger?
Also, this is a BT connect?
Did you have any issues with the device drawing extra power from the battery while the car was off and in sleep mode?
Thank you in advance.
You think this would work even if there is no CD changer in the car? (assuming it is hooked up to the HU)
https://www.discountcarstereo.com/a2d-c5.html
NVM, website says CD changer needs to be working properly for it to work.
Is this what your iSimple 2381's do or do I have very bad unit?
Yours,
Bluemill
Yours,
Bluemill
Like any BT add on device, all music streaming and phone calls go through a selected FM frequency. Here are some major reasons I believe the iSimple is better and I have used both.1. The sound quality is much better. The lighter devices transmit an FM signal through the air to your radio antenna. The iSimple is hard wired to your antenna which means much less chance of any interference. 2. You must find an unused FM frequency with a lighter device or your sound is garbled. The iSimple can use any FM frequency including a station you listen to. 3. If you are traveling with a lighter device and pass through an area with a radio station transmitting on your selected frequency you lose your music streaming and calls. Not true with iSimple. 4. Everything is hidden with the iSimple except the microphone and the tiny control button. 5. The external microphone makes much better conversations for the other party.
Here is how mine is set up. As I said earlier, all add on BT devices need to use an FM frequency. The iSimple lets you use any FM frequency. The station I listen to mostly is 93.5 so I set my iSimple to work on 93.5. I then program the first radio button to be 93.5. As you know, to manually turn BT on or off, you hold the control button for 4 seconds. If a call comes in the unit automatically switches to BT. If I am listening to radio 93.5 and a call comes in, the unit immediately turns on BT, I tap the control button once and I am connected. When the call is finished I tap the button once and the radio continues playing. If I am listening to a different station and a call comes in, the only difference is that I tap the first radio button for the BT frequency and then tap the control button. When the call finishes I tap the control button to end the call and then the radio button I was previously listening to. To stream music from my BT phone I tap radio button 1 to set my BT frequency, hold the control button 4 seconds to turn on BT and play my music. If a call comes in while streaming music all I need to do is tap the control button 1 time because I am already connected to the proper frequency and BT. If I want to switch back to radio, I hold the control button 4 seconds to turn off streaming and listen to whatever station I want. Remember, BT on any of these devices does not work on AM.
I hope this helps you. Let me know if you have any other questions.
