Searching for a fix to my issue with a Kenwood install Bose/PAC kit, A popping noise during start up and during volume number changes. Saw a youtube video referencing GM sends 5V to the amp for startup and most aftermarket headunits send 12v. They used an inline reducer taking the trigger wire down to 5v. It looked like a parking brake bypass, I"m sure its not that, but just for reference, it looks like one.
Anyone here ever heard of that, or used one? My install is all stock Bose, added Kenwood 7709s headunit, used PAC GM1-RST, also has a slight hiss/hum even at zero volume.
Thinking maybe the trigger voltage is hitting the factory amp every time? And maybe I should run a dedicated ground wire for the headunit connections instead of using the factory ground in the stereo harness.
i'm not sure it's even needed, no one seems to have done this with a stock c6 bose going to an aftemarket headunit, I'm probably grasping at straws to get this working.
Can you elaborate on this need for a C5? I have a Joying branded head unit (not looking for opinions on its quality lol) and sometimes the amps come on flawlessly (usually in the morning) and then in the afternoon, or when i go to turn the car on right after it was turned off, the amps don’t come back on. I did make sure it was wired appropriately from the head unit through a ROEM PAC 1, to the cars wiring, so the amp trigger wire is correctly connected, i did grab the accessory power wire for the head unit from the passenger footwell, and so I’m not sure what the problem would be that would make it inconsistent. Now I’m wondering if it’s because of the headunit sending 12 volts instead of 5
while I appreciate the link, I’m kinda looking for an explanation as to why it’s needed in the first place. For reference, no one I’ve seen who installed my radio needed something like this.
Well like VinceC5 pointed out it's a C5 thing and not needed on the C6's, if you're having issues with your C6 there's some other cause to the issues and not the trigger voltage, my guess would be possibly a bad interface, the PAC's are not know for their high quality, others have been know to be bad.
apologies if I wasn’t clear, I actually have a c5 which was why I was so curious
Yes I realize that, my post was meant for the OP, personally I don't know why the C5's are different, perhaps @VinceC5 will jump back in and explain why this is.
The 5V is needed for the diversity antenna trigger. The factory amps do require the 12V. You may want to add a relay to the head unit 12v out. You could be having an issue with the amount of current needed.
