Sponsored by: Innova
2012-13 Bose dash tweeters
Old Aug 14, 2023 | 01:27 PM
hazy's Avatar
hazy
Default 2012-13 Bose dash tweeters
Has anyone successfully replaced the dash tweets on a 12-13 model year?
Curious if it is worthwhile to get a set of 3 way components vs the typical 2 way most seem to use on here.
Figure if the space is available and easy enough to use, why not take advantage
Did a fair bit of digging around here and only found a few dead-end threads
Thoughts from anyone? Or even better....anyone who's done it, post up some pics! Haven't taken anything apart to look at everything, figured this would be a good starting point
Old Aug 14, 2023 | 11:09 PM
VinceC5's Avatar
VinceC5
3 way Def. Worth it. Did that when I had my 13 GS. Had a 10 inch mid bass, 3.5 inch midrange, and 1" tweeter.
Old Aug 15, 2023 | 01:52 PM
hazy's Avatar
hazy
Awesome, good to hear it worked well. 2 questions-
A) did you install the tweeters in the factory dash holes?
B) if yes to the above- was the removal/reinstall of the tweeters fairly straightforward once you got in there?
B2) if you did NOT put tweets in factory location, where'd you mount them?
Really appreciate it!!
Old Aug 15, 2023 | 03:52 PM
VinceC5's Avatar
VinceC5
Yes. I put them in the factory location. The install is simple. They pop right out with a pry tool. The new tweeters can be secured with epoxy. This thread has a couple of pictures.
Old Aug 15, 2023 | 09:56 PM
hazy's Avatar
hazy
Fantastic, thank you!
To 2012-13 Bose dash tweeters
