So the discountcarstereo.com interface seems to have failed after 6 mos... waiting on an email from them. Left side has no sound via Bluetooth. Have searched the forum but maybe looking in the wrong place? Can only seem to find alternative installs not using discountcarstereo.com for ipods.
Is there any other way for me to get either a standard RCA input or headphone input so I can add a real Bluetooth receiver or other ideas. Again maybe I'm searching incorrectly- and yes I want to keep the stock head unit. Thanks!!
Find an FM transmitter that has the inputs you need. Your device connects to the transmitter via Bluetooth, the transmitter connects to whatever FM frequency you program.
Here is one that has an Aux input, you may have to do some searching to find one with the input you want.
Here is one that has an Aux input, you may have to do some searching to find one with the input you want. https://www.amazon.com/dp/B018E0I01I
Thanks but looking for a proper connection not an fm transmitter
