Sponsored by: Innova
carpet removal c5
Old Jan 27, 2003 | 10:50 AM
pdd000's Avatar
pdd000
Default carpet removal c5
i have a 2000 vert. how do i remove the rear carpeting so i can run my wires under it? :smash:
Old Jan 27, 2003 | 05:23 PM
XportC5's Avatar
XportC5
Default Re: carpet removal c5 (pdd000)
C5 carpets are in 4 sections - Rt - Lt frt floor boards, rear vertical section behind the seats and rear trunk/cargo area. If you mean the cargo area, On a vert you first remove the rear trim panels, 4 big plastic nuts that have hooks made on them for the cargo net. Then unsnap the 2 plastic trim panels over the wheels. remove the water fall, remove the rear speaker trim. Then both rear carpet sections can be lifted right out separately.
Old Jan 28, 2003 | 01:26 AM
pdd000's Avatar
pdd000
thanks for the info xport :thumbs:
To carpet removal c5
