Sponsored by: Innova
Help troubleshooting C5 Bose
Old Feb 7, 2003 | 08:57 AM
mhirep's Avatar
mhirep
Default Help troubleshooting C5 Bose
Looking for some help as to where to start troubleshooting the Bose in my 99 coupe. The right side front speaker does not work. All of the other speakers and HU are working correctly.
Any guidance would be appreciated since I really don't want to just start ripping the car apart.
Old Feb 10, 2003 | 04:52 AM
1988L98's Avatar
1988L98
Default Re: Help troubleshooting C5 Bose (mhirep)
Hi
Have you try switching the speaker from side to side, also check for a unplug speaker amplifier.
AL
Old Feb 10, 2003 | 08:47 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Help troubleshooting C5 Bose (1988L98)
Hi
AL
Ditto, make sure the cone isn't damaged. Also remove the speaker assembly, and LIGHTLY, VERY LIGHTLY try to move the speaker in and out, no more than 1/8". If the speaker sounds like a wire brush against a wall or won't move at all time for a new mid/bass woofer. :cheers:
Old Feb 14, 2003 | 12:55 PM
mhirep's Avatar
mhirep
Thanks guys for the info!!!
Old Feb 14, 2003 | 02:40 PM
1988L98's Avatar
1988L98
Hi
Just checking if you found the problem you was having? me and the technican was thinking that a bad speaker amplifier can also cause that problem.
:steering:
AL
[Modified by 1988L98, 1:41 PM 2/14/2003]
To Help troubleshooting C5 Bose
