Sponsored by: Innova
Battery voltage
Old Nov 22, 2024 | 07:33 AM
pinto12's Avatar
pinto12
1st Gear
Default Battery voltage
Hi
The car wouldn't start anymore with the 3.5 year old battery on the weekend vehicle (I noticed engine turn over was getting weaker over time). Naturally I though time to replace. Checking voltage with a multimeter I was surprised to read 12.3V. Charged at home to 12.85 & left disconnected. A day after it's 12.55 and a day after 12.52.
I'm not knowledgeable re car batteries but does this make sense?
Old Nov 22, 2024 | 05:47 PM
madsonp's Avatar
madsonp
If I recall correctly, the minimum voltage should be 12.7V if it’s below that you could have issues. The first thing I suggest doing is taking your battery in and having a load test done on it which a lot of auto parts stores will do for free. If it fails and you do need to replace your battery, put a trickle charger on it when not driving it.
