Sponsored by: Innova
helllllllp!!!!!!
Old Feb 8, 2003 | 04:50 PM
pdd000's Avatar
pdd000
Default helllllllp!!!!!!
i am tryin to wire up my alpine 7998 in my c5 vert. which color wires on the factory harness do i tap into. i have the adaptor so i dont have to cut the factroy harness. i have a yellow 12v power,blue power antenna, black ground, red for the ignition on the alpine harness. which colors on the factory harness do these wires go to. itried a few different ways and nothin worked. i dont wanna hack anymore wires till i know which ones to connect too :confused: :confused: :confused:
Old Feb 8, 2003 | 05:36 PM
M396 #00-011's Avatar
M396 #00-011
Default Re: helllllllp!!!!!! (pdd000)
If you have an adapter, you don't have to worry about it. Just match the adapter colors to the HU's colors.
Old Feb 9, 2003 | 12:19 AM
aurik's Avatar
aurik
Cruise-In IV Veteran
Elite Member
Default Re: helllllllp!!!!!! (M396 #00-011)
The harness should have come with a little list of what wire goes to what. All you really need is +12V, ignition, power antenna, and ground, since you won't be powering th speakers from that head unit.
Old Feb 9, 2003 | 01:50 AM
vrumvrum's Avatar
vrumvrum
I had the same problem.
http://forums.corvetteforum.com/zerothread?id=484700
The adapter worked for me except the switched wire. Apparently the Bose system is turned on by the computer and not a switched power wire. It's just a blank spot in the stock system.
:thumbs:
Old Feb 9, 2003 | 03:00 AM
oblivia's Avatar
oblivia
It sounds like you only have the adaptor that came with your alpine deck.
You also should have had to buy a seperate ($15) adaptor for a GM (1997-2002) vehicle (corvette). If you only have the one that came with your deck and the stock harness from your stock deck you are missing another adaptor the ($15) one for GM.
Keep us posted on that one. :lurk: good luck....
Old Feb 9, 2003 | 04:39 AM
vrumvrum's Avatar
vrumvrum
Default Re: helllllllp!!!!!! (oblivia)
You will still have to tap into the auxilary wires because the stock system has no switched ignition wire. By all means though get the adapter.
:seeya
Old Feb 9, 2003 | 04:00 PM
pdd000's Avatar
pdd000
got it workin. i needed the switched wire under the passenger foot well. thanks for all the help guys. it sounds mint :cheers: :cheers: :cheers:
To helllllllp!!!!!!
