Sponsored by: Innova
neon
Old Feb 10, 2003 | 11:28 AM
pdd000's Avatar
pdd000
Default neon
i wanna put the neon lights in the grills. is there a switched power wire under the hood so i dont have to go back through the firewall
Old Feb 10, 2003 | 03:19 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Default Re: neon (pdd000)
Just run power and ground straight to the battery. To wire your switch you will have to go through the firewall though.
It will help to get aftermarket battery terminal mounts to start wiring up all this new aftermarket electronics you are putting in the car. It will be much more efficient, easier and cleaner if you do.
:cheers:
Old Feb 10, 2003 | 08:00 PM
pdd000's Avatar
pdd000
ya but if i wire right to the battery wont the lights be on all the time????
Old Feb 10, 2003 | 08:08 PM
_Nomad_'s Avatar
_Nomad_
Nope, the power will come from the battery, the switch inside will turn it on and off. You don't want the neons on all the time.
Old Feb 10, 2003 | 08:26 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: neon (The^Nomad)
the switch will have power going to it all the time.. but until you make contact with the switch the neon will be off.
Old Feb 10, 2003 | 09:14 PM
GTLocke13's Avatar
GTLocke13
Default Re: neon (ICULUKN-C5)
Wire it to your headlights. There's really no point to having neons on in the daytime.
Old Feb 11, 2003 | 01:10 AM
oblivia's Avatar
oblivia
Default Re: neon (GTLocke13)
i would defenitly run a switch in a good spot because you don't want the neons on all the time at night either.... :smash:
Old Feb 11, 2003 | 01:26 AM
_Nomad_'s Avatar
_Nomad_
Default Re: neon (oblivia)
:yesnod: Right, like I was saying, you have a switch inside to turn them on and off with. Since the neon's are in the engine compartment there is no need to tap into any other power wires. Simply run power and ground directly to the battery. The switch inside will control when the neon's are on and off by the flip of a toggle or rocker.
Old Feb 11, 2003 | 12:12 PM
92TripleBlack's Avatar
92TripleBlack
Neon: The cars and the bulbs. Just say no. :skep:
Old Feb 11, 2003 | 12:54 PM
kittmaster's Avatar
kittmaster
Default Re: neon (92TripleBlack)
:iagree: If you absolutely have to make this "mod" then make sure the power lead is FUSED.
I don't know why everyone seems to forget this most important point for any additional electrical mod that is done. Not like you can ASSUME that most will do this...........make sure its fused
kitt
Old Feb 11, 2003 | 01:54 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: neon (kittmaster)
I know C5's look great with gill Neons, I wonder how a C3 would look...
I might have to give it a try :D
Old Feb 11, 2003 | 06:42 PM
Big_John's Avatar
Big_John
So...What about a Neon with Neon? Does that count? :skep:
Old Feb 11, 2003 | 10:53 PM
_Nomad_'s Avatar
_Nomad_
:iagree: :lolg: :lolg: :lolg:
The neon kit comes with a fused power wire. If he's able to read instructions and hook it up them He should be ok.
Old Apr 19, 2003 | 01:22 AM
edmaverik's Avatar
edmaverik
If you have a C5, wire the hot wire to circuit #6 and you can control the neons with your factory foglight switch. That is how I have mine. Ground to any place on the chassis.
Click on this picture to expand view of my neons.
[Modified by edmaverik, 1:41 AM 4/19/2003]
Old Apr 19, 2003 | 12:09 PM
SpdKilz's Avatar
SpdKilz
Default Re: neon (edmaverik)
I have numerous wiring diagrams on my site -
http://www.cmeglow.com/wiringdiagrams.html
Also guys, on a EB...would you recomend having blue or white behind the vents???
Carleton
Old Apr 19, 2003 | 12:30 PM
Tolofou's Avatar
Tolofou
Default Re: neon (PepperdineZ06)
Very nice! Like the idea of the neons behind the gills.. I may do this.. Top down lights on.. Sounds wicked..
On a blue car you are safe with white or blue lights.. and use a switch cause police seem to freak if you ride around with neon on..
Rob
Old Apr 19, 2003 | 01:11 PM
Still_Single's Avatar
Still_Single
Default Re: neon (Tolofou)
Check your local police codes - in most states, blue lights anywhere on the car are not allowed and will get you pulled over ...
Old Apr 19, 2003 | 04:03 PM
SpdKilz's Avatar
SpdKilz
Default Re: neon (Still_Single)
Yah, in most states red and blue are the big no no colors...
In illinois, all neon's are illegal....I was pulled over in my old explorer and they said that the purple lights were reserved for an ambulance??? He didn't give me a ticket when i called him on it though (he still could have of course because they all are illegal).
So, in your guy's opinions....would white or blue look better in the grill???
Carleton
To neon
