Sponsored by: Innova
Bypassing non-bose amp C6
Old Sep 17, 2025 | 05:13 PM
jordanberkut's Avatar
jordanberkut
Cruising
Default Bypassing non-bose amp C6
Has anyone successfully bypassed the stock non-bose amp, and reused stock speaker wiring? Currently have an aftermarket headunit, and door speakers, and would like to bypass so that I can get the lower speakers to play more than just low frequency/bass.
Old Sep 20, 2025 | 07:34 PM
TorchRedFred's Avatar
TorchRedFred
It's very easy to run new speaker wires into the doors from under the dash. Probably easier than tapping into existing wiring.
Old Dec 18, 2025 | 05:32 AM
G4bama's Avatar
G4bama
I just did this with my aftermarket amp and speaker install. I used the factory speaker wires for the door subwoofer and the mid rear speakers. I spliced into the speaker output wires from the factory non Bose amp. The door wires are in the small plug (2 ohm side) on the amp and the rear wires are in the big plug (4 ohm side) on the amp. From there I ran my 9wire cable to my amp behind the passenger seat. Not a bad job
To Bypassing non-bose amp C6
