Not sure if this is the place to post this but I figure one of you guys might know. My hatch release, fog lamps and fuel door release buttons are not working. Do I have a blown fuse? If so which one. I can't seem to find any blown fuses so am I barking up the wrong tree? :confused:
Sounds like a blown fuse. I remember a while back somebody had the same problem. All of those things are on the same circuit. Check the owners manual for what fuse does what and check them.
The more important question is why did the fuse blow in the first place? Did you do something that would have shorted out the circuit? Start with the fuses, if they are all okay, post back and we will try to figure out what else could be causing the problem.
