Key FOB(s) & memory settings
On the C5 FOB's I can set the memory 1 or memory 2 based on the key FOB #1 or #2. When I unlock the vehicle, get in close the door and put the key in the ignition the memory would set corresponding with the key FOB #1 or #2.
My question is, "Does the C7 have the same or similar setup memory as the C5's?" if so, how do you coordinate the FOB to the memory settings? Why do you always have to push and hold the #1 or #2 button until the memory setting positions are finished???
What am I missing?
In order to make the Fobs do what you want, you need to determine where they sit in the programming hierarchy. You can do that by going through a programming cycle and trying to "ADD" an additional fob. When you get the car into the programming mode, it will tell you which number fob it is ready to program. If it is any number other than 3, your fobs are not 1 and 2., and won't be able to match your memory settings. If that is the case, you would need to wipe out the memory of your fobs, and reprogram them completely so that they are 1 and 2. Then they will be able to do what you would want. It's really not that hard to do, as long as your car is an American version and NOT Canadian. There are step by step instructions on here about adding one fob to see what the next logical number would be in the memory, as well as redoing all the fobs to get you to 1 and 2 if needed. I
IF your fobs are 1 and 2 already in the system, (when you try to program a new fob it shows it is ready to program fob number 3) you would cancel out of the programming mode. Then you have some other problem with the memory system in your car. You should only have to set the memory settings once, hear the beep that acknowledges they are set, and then you should be good to go.
