Sponsored by: Innova
alt fuses
Old Feb 22, 2003 | 03:51 PM
pdd000's Avatar
pdd000
Default alt fuses
should i use 2 alt fuses or just 1. my new alt is 140 amps and i have a 140 amp fuse and fuse holder. my amp wiring kit came with a 250 amp fuse and holder. should i use both fuses or just one, and if just one which one? pat
Old Feb 22, 2003 | 03:52 PM
pdd000's Avatar
pdd000
Default Re: alt fuses (pdd000)
o and the 140 amp fuse and 250 amp are both alt fuses :)
Old Feb 22, 2003 | 03:56 PM
Metal Wulf's Avatar
Metal Wulf
just use the 140amp fuse, put the fuse as close to the alt as you can, and make sure you use 1/0 ga from the alt to fuse and fuse to batt...
Old Feb 22, 2003 | 04:11 PM
pdd000's Avatar
pdd000
Default Re: alt fuses (Metal_Wulf)
ok thanks :smash:
Old Feb 22, 2003 | 05:14 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Actually you might want to use two fuses. Since both the alt and the battery are capable of delivering power but most importantly since the alt is kind of a long run from the battery on a C5. One ANL fuse close to the alt and one ANL fuse close to the battery. For a car with a shorter distance from the alt to the battery, like say, a C4, would only need one fuse about halfway between the two. I know it seems like overkill but, that is an expensive car and you want to take every precaution you can with it. The reason for this effort is if for any reason, like a car accident or whatnot, that wire gets cut? You now have power still traveling through that wire. As long as the engine is running the alt will deliver power and even if the engine stops, the battery will still deliver power, you see, you want a freak ground like that to blow the fuse on each end effectively neutralizing the wire itself before it can cause harm.
Now about your amp kit fuse, that would most likely be an AGU type fuse. I don't trust AGU fuses with that much power since they are known to be unreliable at times. An ANL type fuse AKA (Wafer Fuse) is much more reliable a fuse. With the power you will run I would use ANL fuses on both the Alt to battery wire and the battery to distro block wire. You can use AGU fuses in the distro block to your amps.
Hope that helps.
P.S. Don't forget all of your ground wires too. They will need to be the same size or larger than your power wires.
:seeya
To alt fuses
