Sponsored by: Innova
tweets
Old Mar 4, 2003 | 01:34 AM
pdd000's Avatar
pdd000
Default tweets
i am running mb quarts components. where should i mount the tweeters. any suggestions or pics :confused:
Old Mar 4, 2003 | 10:24 AM
Conquer's Avatar
Conquer
St. Jude Contributor
Default Re: tweets (pdd000)
I mounted mine in the doors on my 98. Sounded great there! You can also mount them in the pillars just above the dash on each side. Or you could make a template for the MB's where the Bose are.
Its a matter of.....do you want to cut into your car or modify it. If not, keep'em in the doors where the Bose were. I highly suggest you bring them out and up higher though for better imaging. My $0.02. Hope this helps!
BTW.... those are JL XR tweets.
Old Mar 4, 2003 | 12:06 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: tweets (Conquer)
you'll need to try them out in like 10 spots to see where they sound the best, you can't just place them anywhere :thumbs:
Old Mar 5, 2003 | 01:17 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
I really wanna do this but still don't have the courage to cut the hole on my pannel :lol:
Old Mar 5, 2003 | 01:33 PM
brianw21's Avatar
brianw21
Here is my plan....
Take your tweeters, and attach an extra 4 feet of speaker wire. Put some double stick tape on them (3m stuff is good and won't hurt anything). Stick them to various locations (both sides). Each time Listen to them for 5 minutes, then move them back to stock location, and listen again for 1 minute. Try this several times. You will find one you like the most.
Possible Locations we are considering:
1. Stock, Horizontal Aim
2. Stock, Passenger Head Aim
3. Stock, Center Aim.
4. A Pillar, Horizontal Aim
5. A Pillar, Aimed into Windshiled
6. Upper Door, Horizontal Aim
7. Upper Door, Passenger Head Aim
8. Upper Door, Center Aim.
Remeber that if you are using time alignment that you will need to re-adjust after every move... Also if you are running a 6db slope on your tweeters you will have problem moving them to far away from the Mid. You might consider a higher slope.
Brian
Old Mar 6, 2003 | 07:47 AM
Conquer's Avatar
Conquer
Default Re: tweets (mike76002)
I tell ya... my stomach turned when I began to cut into it but was glad I did in the end! Turned out great and sounded even better then expected! If you decide to do it... TAKE YOUR TIME! Lucky for me I did not run into any problems... but I did take my time :) :thumbs:
Old Mar 6, 2003 | 12:57 PM
0Vette Stripes
Former Vendor
Cutting the hole is not the problem to me but I am just worry about the resale value :D
To tweets
