Sponsored by: Innova
Which ARC Amp?
Old Mar 10, 2003 | 03:31 PM
MVP's Avatar
MVP
Default Which ARC Amp?
What one amp would you recomend to power 6.5" Utopias (+/- 150 watts rms) and an IDQ10 ( around 250 watts rms).
Also what are the diffence between the KAR/CXL/XXL lines. I was planning on a getting the CXL, but is it better to wait and get the XXL line or is not worth the extra $$ and just get the KAR series?
Where can I get ARC amps online? The only place I know of is ampmanaudio
[Modified by MVP, 3:32 PM 3/10/2003]
Old Mar 10, 2003 | 03:33 PM
Kale's Avatar
Kale
Default Re: Which ARC Amp? (MVP)
no experience with xxl, kar is the cheaper line... i used a ARC2100 for my utopia 6.5's and it sounded great.
250x1 with arc would be a bridged ARC2050. $300 for a 230 watt sub amp is crazy unless you plan on using it for something elsel ater on. I did.. but now my arc 2050 is jsut on a shelf. So is my IDQ10 that I was using with it.
cost me about $500 for that amp/sub combo.. this time round, I'm going with a much much louder sub and amp for .... $600
[Modified by Kale, 12:35 PM 3/10/2003]
Old Mar 10, 2003 | 03:41 PM
MVP's Avatar
MVP
Default Re: Which ARC Amp? (Kale)
Are you willing to sell them?
I was thinking of getting a 4 channel amp, but I am not sure which one would work :confused:
Old Mar 10, 2003 | 03:50 PM
Kale's Avatar
Kale
I'm a pack rat, don't think I could.
unfortunately arc amps bridge to 2 channel mono. I dont know why they did it that way... seems stupid.
Old Mar 10, 2003 | 03:55 PM
MVP's Avatar
MVP
So I couldn't use their 4 ch. amp?
Why couldn't I just use 2 channels for the Utopia's and bridge the other two for the sub?
Old Mar 10, 2003 | 04:00 PM
Kale's Avatar
Kale
only 85 watts though
Old Mar 10, 2003 | 04:05 PM
MVP's Avatar
MVP
I didn't want to use two different model amps, but what would be a good sub amp for the IDQ10 considering I will use the ARC2100 for the the Utopia's?
Is it OK to use two different brand amps?
Old Mar 10, 2003 | 04:48 PM
Kale's Avatar
Kale
wont hurt anything running different brand amps.
Why not get two dual 4ohm IDQ10's... and a second 2100
run the 2100 in stereo at 2ohmz per channel.. easy 190 watts per IDQ sub.
Old Mar 10, 2003 | 05:21 PM
MVP's Avatar
MVP
Where did you buy your amps at?
Old Mar 10, 2003 | 05:44 PM
Kale's Avatar
Kale
Local authorised dealer.
Old Mar 12, 2003 | 01:43 PM
MVP's Avatar
MVP
Does anyone know where I can get the ARC2100 and ARC 2050 on the internet? :seeya
Old Mar 12, 2003 | 01:55 PM
Kale's Avatar
Kale
ampman is the only lpace i know of
Old Mar 12, 2003 | 02:04 PM
MVP's Avatar
MVP
Thanks :cheers:
To Which ARC Amp?
