Sponsored by: Innova
WinISD
Old Mar 14, 2003 | 03:51 PM
MVP's Avatar
MVP
Default WinISD
I just d/l this program and started to play around with, but I have no idea what I am doing. Can someone explain how to use or is there a website that shows this. I am still learning this whole car audio thing.
Specifically I am trying to figure out box size for an IDQ10 in mike's stealthbox?
TIA
Old Mar 14, 2003 | 04:24 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: WinISD (MVP)
the enclosure sizes are listed here:
http://www.imagedynamicsusa.com/webs...ducts/idq.html
Old Mar 14, 2003 | 04:31 PM
MVP's Avatar
MVP
Default Re: WinISD (Metal_Wulf)
So does that mean that mike's box will be too big? His stealthbox is around 1.1ft^3. WinISD suggested .690ft^3. Driver dispacement is only.05ft^3
:confused:
all sealed of course
[Modified by MVP, 4:31 PM 3/14/2003]
Old Mar 14, 2003 | 04:46 PM
Metal Wulf's Avatar
Metal Wulf
you could always put in a baffle to make the volume less, you need it to be about half the size.
or you can port the sub, which if I was only going to have a single 10" i'd do :thumbs:
Old Mar 14, 2003 | 04:48 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
:confused:
MVP, if you wanna have a smaller volume box, I can do that for you but I just cannot go bigger.
:cheers:
BTW, the box will look the same but I just block the incline part to reduce the volume.
Old Mar 14, 2003 | 04:53 PM
Kale's Avatar
Kale
Default Re: WinISD (mike76002)
.50 after displacement is perfect for an IDq10 with 200-300 watts of power.
...port it :D
[Modified by Kale, 1:54 PM 3/14/2003]
Old Mar 14, 2003 | 05:00 PM
MVP's Avatar
MVP
Default Re: WinISD (Kale)
Mike can you port it?
And will it make if difference if I still have the center cover over it?
Either way Mike, I will send you an IM as soon as I figure out what I want to do. :cheers:
Old Mar 14, 2003 | 05:06 PM
Kale's Avatar
Kale
1 cubic foot, ported to 26hz with decent port area...
unfortunaly a "sound quality port" is very long.
Old Mar 14, 2003 | 05:10 PM
Metal Wulf's Avatar
Metal Wulf
:withstupid:
MVP's Avatar
MVP
How long is very long?
Old Mar 14, 2003 | 05:12 PM
Kale's Avatar
Kale
i dunno off the top of my head, maybe 30" ? you can go shorter, but with less port area. less port area = subwoofer farts on long low tones
Old Mar 14, 2003 | 05:13 PM
Metal Wulf's Avatar
Metal Wulf
could use a slit port
Old Mar 14, 2003 | 05:32 PM
0Vette Stripes
Former Vendor
I would suggest sealed box ... better SQ and less work :D
Old Mar 14, 2003 | 05:35 PM
Kale's Avatar
Kale
tune it right, and ported sounds great... but I dont think it can be done in that box anyway.
Old Mar 14, 2003 | 05:38 PM
Metal Wulf's Avatar
Metal Wulf
:jester
To WinISD
