Sponsored by: Innova
Headunit Help
Old Mar 19, 2003 | 02:10 AM
knesbitt's Avatar
knesbitt
Default Headunit Help
Just go my Pioneer Premier Headunit in mail and planning to install this weekend. Is there a wire for Illumination in the C5 or should I wire 12V+, ACC, and Illumination all to the same wire?
Old Mar 23, 2003 | 10:07 AM
Conquer's Avatar
Conquer
St. Jude Contributor
Default Re: Headunit Help (knesbitt)
I would leave the illumination out.
Old Mar 23, 2003 | 01:56 PM
Leadfoot77's Avatar
Leadfoot77
also, if you wire your +12 V and ACC to the same wire, your headunit will not "remember" your radio station settings, EQ settings, etc. I too would leave the illumination out.
Old Mar 28, 2003 | 10:24 AM
knesbitt's Avatar
knesbitt
Default Re: Headunit Help (Leadfoot77)
Where should I connect ACC to then? I am not getting any signal to the wiring harness to ACC. It appears as though I have to by pass it. Does ACC goe though the BCM?
Old Mar 28, 2003 | 01:25 PM
MVP's Avatar
MVP
I think it is the same place everyone gets the V1 power wire from. Check the tech tips for Hardwire V1.
To Headunit Help
