Sponsored by: Innova
Help please???
Old Mar 24, 2003 | 08:57 PM
Curveit's Avatar
Curveit
Default Help please???
While looking for a courtesy lamp delay, I disconnected a little black thingie
with a printed circuit inside. Everything looked OKso I plugged it back in.
Now my Pioneer doesn't come on at all. My car is an '86; this thing is located
on the right side, behind the ac duct. It has #14078971 on it.(no luck with local Chevy dealer). It has 4 wires into it.. pink/black, green,black, and grey.
Any help id'ing this thing ??? I don't even know what it is to buy a new one if I need it!
Thanks for any help
:confused: :confused: :confused:
Old Mar 26, 2003 | 04:29 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
Default Re: Help please??? (Curveit)
I looked @ my 86 electrical diagnosis manual & could not find any device with that combination colors on the wires, On my 86 there is a black box about 1x1 inches it is located under the passenger side of the dash all the way over to the right, is this what you
are talking about?. Keep in mind that the amp relay is some place behind the I/P & to the right of the radio. :flag
Old Mar 26, 2003 | 07:13 PM
Curveit's Avatar
Curveit
:seeya Thanks for responding! That's about the size of this thing...It's
located between the large and small AC ducts. The wire colors are correct.
It has a printed circuit with a bunch of little diodes, or something on it. The local Chevy dealer didn't have a clue over the phone, so I guess I'll just take it in tomorrow and see what we can find out about it. #14078971(623)(913)
By the way, where can I get wiring diagrams? Down load, or do you have to purchase them? I've been lucky I guess, haven't had any electrical problems until now.
( Drive it) gave me a discription of the courtesy lamp delay, but I don't seem to have it anywhere. Same with the amp relay.
Again, thanks for any help. :thumbs:
Old Mar 26, 2003 | 08:52 PM
bogus's Avatar
bogus
you need a Helms Manual.
Old Mar 27, 2003 | 04:37 PM
Curveit's Avatar
Curveit
:rolleyes: Took the module in today...after much searching they think it's a "low coolent level module" but they're not sure. Printed me up a couple sheets of Alldata diagrams and that should help some. They're not Bose though, and don't show an amp relay. Told me to check fuse links...are they all located behind the battery? They didn't know. It looks like my problems are with the #40 circuit, or fuse-link M, where It's at I don't know. Any ideas?
Looked up HELMS, 86 isn't avaliable at this time. Cut my hand rather badly on the lower panel brace; I quit until Monday. Again, thanks!
Old Mar 28, 2003 | 07:13 AM
zaragoza's Avatar
zaragoza
I could scan or make copies of electrical diagnosis manual and send them to you>
Old Mar 29, 2003 | 07:24 PM
Curveit's Avatar
Curveit
:seeya That would be darned nice of you if possible. I don't have a fax machine, so if there's any other way that would be fine. If a fax is necessary I can give you my sisters' fax nr.
I went back to the Chevy dealer and got an additional page which includes the lamp delay. Monday I'll take the dash apart again, and go from there. You've been very helpful, thanks.
Old Mar 29, 2003 | 10:12 PM
zaragoza's Avatar
zaragoza
When I get home sunday nite I will scan the prints & send you copies. :cheers:
Old Mar 29, 2003 | 10:28 PM
zaragoza's Avatar
zaragoza
I found a 1985 corvette electrical diagnosis manual from a palce called abebooks. they seem to be a broker for other sameller book sellers. http://www.abebooks.com
the actual seller was fred chaparro 1508 west magnolia blvd. burbank ca. 91506
I do not have his e-mail . But like I said in my other post when I get home i will make copies for you.
Old Mar 29, 2003 | 10:36 PM
zaragoza's Avatar
zaragoza
I just searched on http://www.abebooks.com under key word corvette and this is copy of what I found. this is the one I purchased.
. CHEVROLET MOTOR DIVISION
1985 CORVETTE
DETROIT, MICHIGAN GENERAL MOTORS CORPORATION 1985. NEW OLD STOCK. LOOSE SECTION OF ELECTRICAL DIAGNOSIS FOR THE 85 CORVETTE,ALL PAGES THERE JUST NOT IN FACTORY BINDER. NEED MORE. E, ME. Binding is 5 RING. Bookseller Inventory #000889
Price: US$ 20.00 (Convert Currency)
Bookseller: Fred Chaparro, Burbank, CA, U.S.A. (Search this Seller's Books)(Ask Bookseller a Question)
:cheers:
Old Mar 29, 2003 | 11:15 PM
zaragoza's Avatar
zaragoza
One more bit of info. check your courtesy light fuse.
To Help please???
