Sponsored by: Innova
2, 4, OR 8 OHM....I HAVE NO IDEA!!
Old Mar 27, 2003 | 10:31 AM
TJKirby82CE's Avatar
TJKirby82CE
Default 2, 4, OR 8 OHM....I HAVE NO IDEA!!
I am going to purchase two 8" subs to hook up to my us acoustics amp. It is a 2 channel with a minimum brigede impedence of 4 ohms.
Should I buy two 8 ohm subs...?
or
Should I buy two 4 ohm subs..?
So do I bridge the amp or run seperate channels...please help.
BTW what is the crossover slope adjustment for?
Old Mar 27, 2003 | 10:51 AM
MVP's Avatar
MVP
Default Re: 2, 4, OR 8 OHM....I HAVE NO IDEA!! (TJKirby82CE)
Go here http://www.eatel.net/~amptech/elecdisc/caraudio.htmand click on the Series/Parallel Impedence on the right (it is a ways down)
This site may be able to answer you other questions also.
Sorry I don't know the answers the questions as I am still learning also, but this site helps out a lot.
Old Mar 27, 2003 | 12:37 PM
M396 #00-011's Avatar
M396 #00-011
Yes, two 8 ohm subs wire in parallel (both pos and neg ran together) will give the amp a 4 ohm mono load when you bridge it. Most amps bridge using left + and right -.:yesnod:
or
Nope
Bridge the amp as stated above.
Slope adj is used to adj the crossover frequency slope, ie 6dB, 12dB, etc. Laymens, its how fast it cut's off the freq. Freq adj, thus adj the freq point at which the slope starts to cuts-off.
Old Mar 27, 2003 | 01:24 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Re: 2, 4, OR 8 OHM....I HAVE NO IDEA!! (M396 #00-011)
Just remember DVC and SVC subs are wiring differently
:cheers:
Old Mar 27, 2003 | 03:15 PM
TJKirby82CE
Default Re: 2, 4, OR 8 OHM....I HAVE NO IDEA!! (mike76002)
Differently how......??
I am getting the 8 ohm DVC RF sub...do they make a 8 ohm SVC?
And what the heck is the difference? :crazy:
Old Mar 27, 2003 | 03:20 PM
0Vette Stripes
Former Vendor
Check this out and you will know the diff
http://www.crutchfield.com/infocente...rs_wiring.html
:cheers:
Old Mar 27, 2003 | 04:10 PM
TJKirby82CE
Thanks everyone,
I have decided to get a RF SVC 8 ohm subs and wire them to mimick a 4 ohm load so I can bridge my amp. Now I need to decide between the punch series or the punch Z series.-TK
:cheers:
Old Mar 27, 2003 | 04:15 PM
leolufse's Avatar
leolufse
How many watts per channel is your amp? Do you want to wire 1 or 2 subs?
You can bridge your amp into an 8 ohm load, or run it in "stereo" and power 2 4 ohm loads. If you are running 1 sub, I'd bridge the amp and wire the sub at 8 ohms. If you are running 2 subs, I would run the amp in stereo mode and wire the subs at 4 ohms a piece. You will get roughly the same power output per sub, but the amp will run cooler and produce cleaner power. A lot depends on the power output of the amp. You don't want to "under drive" your subs.
BTW. A single voice coil sub can only be wired at its rated impedance. In other words a 4 ohm SVC sub, has a 4 ohm impedance. A dual voice coil can either be wired double or half of what is is rated. In other words a 4 ohm DVC sub can be wired in series to achieve an 8 ohm impedance, or wired in parallel to achieve a 2 ohm impedance.
At this point, when you wire multiple subs in series, you add the resistance, but when you wire them in parallel, you divide the resistance by the number of speakers.
For example. Three 4 ohm impedance subs wired in series would be a total impedance of 12 ohms. But three 4 ohm impedance subs wired in parallel would be a total impedance of 1.33333 ohm. (4/3).
:cheers:
Old Mar 27, 2003 | 11:13 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Thanks everyone,
:cheers:
Since you are getting the SVC sub get the Punch HE series. The Z series sucks. You want the 8" sub right? I believe the model # is RFP3808 I believe. Being a SVC sub get the 8-Ohm model and wire in parallel to get a 4-ohm mono load on the amp.
To 2, 4, OR 8 OHM....I HAVE NO IDEA!!
