Sponsored by: Innova
Noise problem C-3??? (update)
Old Mar 31, 2003 | 08:02 AM
Steve Adkins's Avatar
Steve Adkins
Default Noise problem C-3??? (update)
OK, I have narrowed it down to the antenna. When I unplug the antenna the noise almost dissappears. You can still hear it a little with the volume all the way down. Also, when I disconnect the alternater the noise goes away. I have seen filters for the antenna and the alternater. Is this my solution? Should I use ant and alt filters? Thanks!
Old Mar 31, 2003 | 11:13 PM
gdh's Avatar
gdh
Default Re: Noise problem C-3??? (Steve Adkins)
I would definately add the alt. rfi suppression filter from MSD or another high quality source. I have heard that those sold at Radio Shack do not work well.
Old Apr 1, 2003 | 06:08 AM
Steve Adkins
Default Re: Noise problem C-3??? (gdh)
OK thanks! I ordered one from Crutchfield.
Old Apr 1, 2003 | 04:02 PM
TJKirby82CE's Avatar
TJKirby82CE
I will try the same! :cheers:
Old Apr 8, 2003 | 12:01 PM
TJKirby82CE
Default Re: Noise problem C-3??? (TJKirby82CE)
STeve- Any luck?
Last night I removed my radio and rewired it. No power cords near any of the RCA cables.
I installed a CHEAPO noise filter in line before the stereo.
I grounded the chassis of the stereo to the car. I checked Grounds to the stereo no problem. Grounds to AMP are excellent.
I unpluged the Antenna!
STILL REALLY BAD INTERFEARENCE. WHEN THE CAR RPM'S INCREASE SO DOES THE NOISE.
Have you had any luck IM getting :mad -TK
To Noise problem C-3??? (update)
