Sponsored by: Innova
AMP PROBLEM HELP!!!!!!!!
Old Apr 29, 2003 | 04:39 PM
WILDONETHIRTYSEVEN's Avatar
WILDONETHIRTYSEVEN
Default AMP PROBLEM HELP!!!!!!!!
Ok I have 2 Problems I am bench testing a system before installing it. My first problem is when you turn on the radio the system work fine but if you turn the volume up more than half way the amp kick off and then resets and does not stay on--What does this mean? Number 2 my Mono amp keeps blowing fuses. It is wired correctly put different amp in it place and works fine--What does this mean? any help would be appreciated thanks :confused:
Old Apr 29, 2003 | 05:11 PM
leolufse's Avatar
leolufse
Default Re: AMP PROBLEM HELP!!!!!!!! (WILDONETHIRTYSEVEN)
What is your power source? If you are just using a battery, it doesn't take long for it to lose charge. Many amps are designed to shut down if they are not getting enough volts or amps from the power source.
Old Apr 29, 2003 | 05:38 PM
WILDONETHIRTYSEVEN
Thanks If I hook up a Charger to the batterry and then run the system will that work?
Old Apr 29, 2003 | 06:06 PM
leolufse's Avatar
leolufse
If you have one of those chargers that has the 70 amp "start mode", it might work. But do not hook up a charger to the battery and hook up your stereo stuff. A battery charger works by sending current through the battery backwards to re-energize the plates in the battery. This could have a detremental effect on your equipment.
Old Apr 29, 2003 | 08:47 PM
C5B's Avatar
C5B
Your amp(s) may have input overload protection. Turn the gain all the way down on the amps, then turn up the volume all the way up on the head unit, then turn up the gain until the speaker/amp starts to clip.... then back off the gain until it is clean.
Also, I have never seen a battery charger charge 'backwards' as leolufse has stated..... but they DO have a significantly higher output voltage depending on the type of charger. Plus, the chargers are usually very non-clean sources of power (like no filtering so you get tons of buzz). The charger can fry things if the battery doesn't soften the charger's output by taking a good charge.
I recommend going to Radio Shack or Fry's electronics and buying a decent 12V/13.8V/14.4V power supply (any of those voltages will do). If you run a small powersupply (5A or so) in parallel with a good battery, you'll be able to test all you want... keyword: TEST. I wouldn't try to run pounding bass for more than a few minutes with that setup.
- C5B
Old Apr 30, 2003 | 02:12 PM
WILDONETHIRTYSEVEN
Thanks guys my batterry was not charged enoungh. After charging, bench test was perfect. 3 amps and 2 c/o, cap, sub plus more all tested perfectly thanks
To AMP PROBLEM HELP!!!!!!!!
