Sponsored by: Innova
C5 Speaker removal help!
Old May 12, 2003 | 10:54 AM
sboxster's Avatar
sboxster
Default Re: C5 Speaker removal help! (leolufse)
Full specs:
Driver Mounting Depth
Top Mount 2-1/4" (5.71cm)
Bottom Mount 2-1/2" (6.35cm)
Grille
Height 9/16" (1.43cm)
Diameter 6-1/8" (15.56cm)
Cut-out
Driver Cut-out Diameter 5" (12.70cm)
Old May 12, 2003 | 11:44 AM
leolufse's Avatar
leolufse
Default Re: C5 Speaker removal help! (sboxster)
Full specs:
Grille
Cut-out
They will fit. The top mount depth is only 1/8" more than the Kappas.
However I noticed that the cut-out diameter seems pretty big for a 5.25" speaker. It is only 4.75" on the Kappas. Are you sure you have the right specs? It says the speaker diameter is 6- 1/8". You need a 5.25" if it is a vert, z06, or FRC. You need a 6.5" if it is a coupe.
Old May 12, 2003 | 12:01 PM
sboxster's Avatar
sboxster
Check out this link:
http://www.polkaudio.com/car/specs.php?name=ex352
Old May 12, 2003 | 12:25 PM
leolufse's Avatar
leolufse
Something doesn't make sense. Crutchfield doesn't have the correct specs for these either. They have the cut out diameter at 4-15/16 for both the 5.25" and the 6.5" version. I'm not sure who to belive.
The Kappas are a much better speaker than these anyhow.
Old May 12, 2003 | 01:06 PM
sboxster's Avatar
sboxster
Okay I will go with the Kappa's..
I got the Polk mm6 in the front (components) so I figured to stay with the same brand.
Old May 19, 2003 | 10:54 AM
sboxster's Avatar
sboxster
Fronts and rear speakers are IN!!
Whew.. no issue, the rear is too easy..
