Sponsored by: Innova
Reflection on C5 stereo install
Old May 18, 2003 | 07:50 PM
ericdwong's Avatar
ericdwong
Default Reflection on C5 stereo install
...I used the OEM headunit and tapped the signal off of it. I spent $0 on the system as all the components were taken out of my old car. I'll put pics up later. Im running front speakers only now, I thought about adding the rears but I think it sounds fine the way it is, so I might skip the rears.
The good parts:
Easy integration with the OEM system
The C5 has plenty of flat panels for easy mounting of amps/electronics/crossovers
The doors have plenty of room for different speaker options
Doors have plenty of flat spaces
The bose was easy to dissassemble (door pods just unplugged and came out as 1 piece)
Wires were easy to run (carpeting in many pieces, easy access to run speaker wire to doors)
Top removed for more space to work
No worry about the power wires grounding out as there arent many grounds in the car
No extrenuous alternator whine
The pain in the butt:
I had to fabricate my own mounts of the speakers in the doors
GROUNDING THE REAR AMP
My 2 18" woofers hit too hard so it makes the OEM cd changer skip
Old May 18, 2003 | 08:49 PM
Kale's Avatar
Kale
Default Re: Reflection on C5 stereo install (eRiCdWoNg)
How hard do they hit? Get 'em metered. :steering:
Old May 19, 2003 | 10:32 AM
mikejaeggi's Avatar
mikejaeggi
I had that problem too with the Alpine changer, put it in one of the side compartments and it solved the problem.
Old May 19, 2003 | 09:40 PM
ericdwong's Avatar
ericdwong
Default Re: Reflection on C5 stereo install (mikejaeggi)
I did this today and indeed it worked. Its a little harder to get to cause of my box. Right now I just balled up the changer in a buncha towels and stuffed it in there. I will come up with a more permanent solution later. I'm thinking of suspending the CD changer by springs to further give it shock resistance.
I dunno how long I'm gonna keep the 2 18s in there though. They are very loud and its gonna take a toll on my hearing. Not only that the car is slower and handles worse.
Oh yeah
Old May 19, 2003 | 11:02 PM
mrkln's Avatar
mrkln
Holy big drivers batman. I can honestly say that I have not seen that setup yet. That has got to be INSANELY loud. :crazy:
Old May 19, 2003 | 11:08 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Reflection on C5 stereo install (Kale)
:withstupid:
Old May 20, 2003 | 02:31 AM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Re: Reflection on C5 stereo install (Metal Wulf)
Holy cow :D Can human ears handle those 2 18's :D and specially in a coupe
[Modified by mike76002, 1:32 AM 5/20/2003]
Old May 20, 2003 | 09:02 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Been there tried that. :U Make sure the springs are wel supported (in the suspension state) so as to not inflict more vibration on the lazer pickup. :thumbs:
To Reflection on C5 stereo install
