Sponsored by: Innova
Rear Speaker Question?
Old May 27, 2003 | 06:41 PM
WILDONETHIRTYSEVEN's Avatar
WILDONETHIRTYSEVEN
Default Rear Speaker Question?
Can you put a 5 1/4 mid range ( in a vert) and also put a tweeter surface mount also for better sound? What do you guys think?
Old May 27, 2003 | 06:46 PM
leolufse's Avatar
leolufse
Default Re: Rear Speaker Question? (WILDONETHIRTYSEVEN)
You could get a set of 2 way 5.25" coax speakers. Or get a component set that has a bracket to hold the tweet over the center of the woofer. Those two options will make for the easiest install. Or you could cut into the trim panels to place the tweets about 6" from the woofers. Any of these options are not going to give you much in terms of good imaging. I'd rather see you spend the money on a better set of components up front and a more powerful amp to run them.
