Sponsored by: Innova
88 Rear 6x9's
Old Jun 2, 2003 | 08:50 AM
Tourney3p0's Avatar
Tourney3p0
Default 88 Rear 6x9's
Hey guys,
I replaced my head unit awhile back and temporarily put a set of junker 6x9's in the rear so that I wouldn't have to deal with Bose incompatibility. I noticed that the speakers don't exactly fit up to my mounting points in the rear, so I had to fabricate a crude mount out of a board.
I'd like to not have to use any sort of mount in the rear now that I'm going to put some permanent speakers in. Can someone tell me a set of decent speakers that will fit with no mount? I don't need or want to impress anyone with my system. As long as I can listen to CD's I'm alright.
Old Jun 3, 2003 | 03:31 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: 88 Rear 6x9's (Tourney3p0)
my 6x9's fit in the back of my 87 with no mods at all. :confused:
Old Jun 3, 2003 | 03:40 PM
Tourney3p0's Avatar
Tourney3p0
Default Re: 88 Rear 6x9's (TIMSPEED)
Which 6x9's do you have? Like I said, I'm using a junker set right now.. it's some 3-way Pioneer 6x9's, which theoretically should be sufficient.. only they're like 10 years old and paper. The bass sounds like crap.
I borrowed a set from a friend to see if they'd line up (also Pioneer 6x9's, but much newer) and they didn't. They were, however, of a different bolt pattern than the ones I'm currently using. Maybe it's just some models of Pioneers that aren't quite right?
Old Jun 3, 2003 | 04:07 PM
sboxster's Avatar
sboxster
I have some good 6x9's used. There Blaupunt's that I had in my firebird. There three way. Lemme know if you want them.
Old Jun 4, 2003 | 12:09 AM
DF's Avatar
DF
I have a pair of Infinity Kappa 693I 3-Way 6X9's in the back. I used the stock 6X9 mount that was in the car. The holes didn't line up, but it was easy to install them anyway. I used bolts and a flat washer on each side of the speaker to mount them and it worked perfect.
Here are pics to illustrate how I did it.
Other info is on my website if you are interested:
http://www.corvetteforum.net/c4/df/
Old Jun 4, 2003 | 08:45 AM
Tourney3p0's Avatar
Tourney3p0
Default Re: 88 Rear 6x9's (DF)
Thanks, at least this confirms that my car isn't a freak and everyone else is having no problems with perfect mounting.
I read through your page and appreciate the information. The info on the door speakers was informative as well.
Old Jun 4, 2003 | 09:59 AM
DF's Avatar
DF
No problemo! :cheers:
Old Jun 4, 2003 | 04:58 PM
TIMSPEED's Avatar
TIMSPEED
I'd show you pics of my setup, but my vette isn't here right now :(
I did a complete change over from Blowse, to JVC/Sony XPlod.
I got 6½'s in the doors, and 6x9's in the back, and it sounds GOOD!
To 88 Rear 6x9's
