Sponsored by: Innova
Alpine CDA-7998 capacitor question
Old Jun 5, 2003 | 06:08 PM
MY2K2C5's Avatar
MY2K2C5
Default Alpine CDA-7998 capacitor question
Howdy all:
I asked a while back about where to get the capacitor recommended by Alpine for the 7998 to get the Auto close function to work. I purchased two of them at Radio Shack and installed the first one and thought I had the polarity correct and it fried... :mad
I then tried the second one and reversed the polarity of the first and it fried as well. I have the standard 12V Bosch relay setup and have no other problems whatsoever with my system.
Question is: Does anyone have a part number for the capacitor. I would like to try again. I am sure plenty of people have done this and I would like to know which cap they used. Might have had a bad batch from Radio Shack.
Thanks,
Old Jun 6, 2003 | 04:33 PM
MVP's Avatar
MVP
Default Re: Alpine CDA-7998 capacitor question (MY2K2C5)
How did you wire your HU? I just installed my last weekend and it closes automatically. BTW this is in a C5, don't know what you have?
Old Jun 6, 2003 | 04:54 PM
MY2K2C5's Avatar
MY2K2C5
Default Re: Alpine CDA-7998 capacitor question (MVP)
Mine is a an 02. I have it wired as it should be wired for usage of a relay for the amps. Did they fix the problem with the CDA-7998? They had a tech bulletin on what and where to install the capacitor on their website. I then looked for that type of capacitor but couldn't fine one exactly to their specs but a forum member said that he had used a certain one and it worked ok. Didn't quite work for me... :lol: First one was good until I got about 1/4 mile from the house and it started smoking from my amp rack :mad
Glad to hear that yours works as it is supposed to.
Here is what Alpine has on their website about it.
Subject:
My CDA-7998/CDA-7897 will not Auto-Close when ignition is turned off
Using a Non-Alpine brand amplifier or an external relay may cause instability in the CDA-7998/CDA-7897's remote turn-on circuit. Due to some of the electrical components in the vehicle, the power feed may lack proper masking (filtering) to the CDA-7998/CDA-7897. This could cause the auto-close function not to work properly when the ignition is turned off. To ensure proper operation, it is recommended that a electrolytic capacitor is installed with a relay. Please refer to the attached PDF document.
The PDF is the tech bulletin that details the capacitor and it's placement in the circuit.
thanks,
I just looked at the PDF and it is different than the tech bulletin I had last fall. IT now says you can use a diode to fix the problem. I will try that this weekend. That would make more sense to me than the capacitor.
[Modified by MY2K2C5, 1:56 PM 6/6/2003]
Old Jun 6, 2003 | 05:33 PM
MVP's Avatar
MVP
:confused: I didn't use any relays for my amps. Maybe that is it. :crazy:
To Alpine CDA-7998 capacitor question
