Sponsored by: Innova
Sound Deadening article published...
Old Jun 9, 2003 | 04:52 PM
brianw21's Avatar
brianw21
Default Sound Deadening article published...
We got an astounding 8 db difference with the L-comp and Brown Bread combined.
http://www.hometheaterhifi.com/volum...ng-6-2003.html
Hints for corvette guys:
1. Cover everything with brown bread.
2. Do two layers everywhere, except by drivers pedals.
3. Put L comp on floor and behind seats / tranny tunnel, back deck.
We got an astounding 8db difference. Much more than I could have expected. I still need to work some magic on the door panels, and they have a 400hz vibration that is driving my nuts...
Brian
Car Audio Editor
Secrets of HomeTheater
[Modified by brianw21, 3:52 PM 6/9/2003]
Old Jun 9, 2003 | 05:04 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Sound Deadening article published... (brianw21)
:eek: :cool: :thumbs:
Old Jun 9, 2003 | 08:18 PM
DSTJ99's Avatar
DSTJ99
sounds great. Here is a trick for the doors.
I used rubberundrecoating from pepboys. It is the same spray stuff from dynamat. You can purchase it for $5 a can and I used two cans to do both doors. Stick with the can with they typical spray paint nozzle, the larger one leaked too much.
I took off the doors and tightened everything down. Then I removed the bose grill and glued the plastic cage piece down. It was a noise maker. Next, i sprayed two coats on the doors and let them dry over night. I think i added about two pounds of stuff to each door.
My doors are quiet as can be. There are no noises at all!!! Plus, you can not tell that the door is covered in undercoating. I let the panels dry for 24hours before reattaching them.
Old Jun 10, 2003 | 04:30 AM
M396 #00-011's Avatar
M396 #00-011
1st off, you stole the line from my Sig, Easy Bake Oven, I want royalties, :jester
I've been working with some stuff similar to L comp. We had a 6dB loss on a coupe with long tube headers and basically straight pipe exhaust. :crazy:
Old Jun 10, 2003 | 02:14 PM
brianw21's Avatar
brianw21
Default Re: Sound Deadening article published... (M396 #00-011)
I love that term, and after putting in Brown Bread in a 103Deg garage, well it was fitting.
Most people never consider the L-Comp, but it is amazing stuff. I used 4 boxes.
1 box = Driver side floor
1 box = Passenger side floor
1 box = rear deck
1 box = behind seats
Old Jun 10, 2003 | 11:47 PM
msuc5vette's Avatar
msuc5vette
Cool article, about how much weight do you think was added to the car?
Old Jun 11, 2003 | 09:18 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Basically? Hey It's all longtubs/straight pipe, at least until the vehicle inspector starts looking :D
Old Jun 11, 2003 | 05:35 PM
leolufse's Avatar
leolufse
Default Re: Sound Deadening article published... (msuc5vette)
:withstupid:
Interesting article.
Old Jun 11, 2003 | 05:51 PM
brianw21's Avatar
brianw21
Default Re: Sound Deadening article published... (leolufse)
Well:
1 Roll Brown Bread: .4lb/ft^2 * 70 = 28lbs
4 Rolls L-Comp: 8lb /roll * 4 = 32lbs
1 JL 12W7 = 40lbs
JL 1000/1 = 15lbs
JL 450/4 = 15lbs
JL 300/2 = 7lbs
5 lbs of MDF
so....
142 LBS... but it was so worth it. The car is much less tiring on longer runs. That 8db difference is VERY noticeable. And the dampning was distributed evenly over the car so the 50/50 isn't messed with.
The amps and processor are before the front wheel, with the sub in the back. I haven't noticed any ballance changes.
The 12W7 hits hard enough that you can fell the wind around the tonnoue cover into the seating area... so better AC :)
Old Jun 11, 2003 | 06:48 PM
Metal Wulf's Avatar
Metal Wulf
:cool: :thumbs:
I'm not sure if I'm going to use Brown Bread or eDead v2. I'll have to add the L-Comp to the shopping list :thumbs:
Old Jun 11, 2003 | 06:52 PM
brianw21's Avatar
brianw21
I also have a 95% box of Brown Bread. If you are thinking of doing your call make an offer.. as I don't need the remaining.
That is 95% of the big roll BTW... :)
Old Jun 12, 2003 | 12:48 PM
Mike Mercury's Avatar
Mike Mercury
YOWZA! :cool:
The most important thing to remember when using a Viscoelastic Deadener is its adhesion to the surface.
amen to that :cheers:
[Modified by Mike Mercury, 12:49 PM 6/12/2003]
Old Jun 12, 2003 | 03:43 PM
Metal Wulf's Avatar
Metal Wulf
thanks for the offer, but I'm no where ready for it yet :seeya
Old Jun 13, 2003 | 01:25 AM
ericdwong's Avatar
ericdwong
I'd like to do this sometime. Thanks for the writeup.
Old Jun 15, 2003 | 12:02 AM
DR_King's Avatar
DR_King
Brain,
Excellent article and website. I'm looking forward to future installments.
To Sound Deadening article published...
