Sponsored by: Innova
Wiring 101 (radio)
Old Jun 9, 2003 | 10:07 PM
DNAST1's Avatar
DNAST1
2025 C8 of the Year Finalist - Modified
2023 C5 of the Year Winner - Modified
2023 Corvette of the Year Finalist (C8) - Modified
2023 Corvette of the Year Finalist (C6) - Modified
2022 C8 of the Year Winner - Modified
2022 C6 of the Year Winner - Modified
Default Wiring 101 (radio)
I have a wiring 101 question, I have a alpine 7894. It calls for me to hook power directly to the battery. In my Honda, I don't remember using the red wire (Ignition), and as far as the red wire on the unit and the harness goes, do I join these together, and splice it to what? Should it be the aux wire on the pass side? Right now I have power going to the unit, however it will not turn on. Another thing that with my tester, I am only getting power from the direct wire to the battery from the harness, and the yellow (constant battery pwr/memory) with the ignition turn on.?????
I DID WHAT THE MEMBER SAID BELOW, AND NOW IT WORKS FINE. I DID NOT NEED THE HARNESS AT ALL :( THANKS
[Modified by DNAST1, 7:12 PM 6/10/2003]
Old Jun 10, 2003 | 01:02 PM
MVP's Avatar
MVP
Default Re: Wiring 101 (DNAST1)
I am not sure what your question is, but when I wired up my 7998 I ran the Yellow wire back to the battery and the ignition wire (not sure what color it was) to the AUX power in the passenger footwell. Hope that helps
