Sponsored by: Innova
1996 Double Din?
Old Jun 17, 2003 | 10:39 PM
Blue J's Avatar
Blue J
Default 1996 Double Din?
I am looking to copy one of the other members and put a CD Changer and CD head unit in my car, and I need to know if the opening is double DIN in the 1996. It looks like it is, but I did a little photoshop magic, and the two don't look like they would fit without cutting.
Old Jun 18, 2003 | 12:46 AM
KDuniverse's Avatar
KDuniverse
Default Re: 1996 Double Din? (Blue J)
do a search
Old Jun 18, 2003 | 12:56 AM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
I don't think it is, Blue. I think it's not a standard DIN, 2DIN or 1 1/2 DIN
Go over to a website that sells the "Direct-fit" Pioneer DEH-something units that are GM and Chrysler specific, and see what the faceplate dimensions are.
Old Jun 18, 2003 | 07:35 AM
Blue J's Avatar
Blue J
I did a search, and didn't come up with anything, it just dosen't look the right size to me, some one around here must have put an aftermarket Radio in there 1996?
Old Jun 18, 2003 | 07:40 AM
TheWacoKid's Avatar
TheWacoKid
Cruise-In II Veteran
Cruise-In III Veteran
I'm almost positive that it is a 1 1/2 DIN opening, so you probobly wouldn't be able to fit a changer and a cd player in the normal opening. You could always get the adapter that has a cd holder underneath the single DIN opening and mount the changer somewhere else. Or it might be possible to make the opening a little larger but I am not sure if it is possible, I haven't worked on a newer C4 before. It is possible to do it on pre-90 vettes. :cheers:
Old Jun 18, 2003 | 10:28 AM
fasteddez's Avatar
fasteddez
Default Re: 1996 Double Din? (TheWacoKid)
it is a double din...
Old Jun 18, 2003 | 11:39 AM
KDuniverse's Avatar
KDuniverse
Default Re: 1996 Double Din? (fasteddez)
http://forums.corvetteforum.com/zerothread?id=576474
To 1996 Double Din?
