Sponsored by: Innova
Use sound deadening material ?
Old Jul 9, 2003 | 08:25 AM
Stingraynut's Avatar
Stingraynut
Default Use sound deadening material ?
I’ve removed the rear Bose units and replacing with 6x9’s. They will fit the Bose plastic housing OK, I was just wondering if I should fill up the cavity with deadening material or leave it empty ?
TIA
S’nut
Old Jul 11, 2003 | 09:55 PM
yeagerda's Avatar
yeagerda
Default Re: Use sound deadening material ? (Stingraynut)
In general, enclosures do better with some damping. By 'sound deadening material' I assume you mean fiberglass or something similar? Also, such material will tend to make the enclosure 'look' larger to the speaker. Try it.
Old Jul 12, 2003 | 12:25 AM
Stingraynut
Default Re: Use sound deadening material ? (yeagerda)
Thanks yeagerda, I was beginning to think my question was too hard to answer !
Meanwhile I have fitted the speakers using the existing enclosure and front cover. I didn’t put any material in as there wasn’t any before. Now I’ll wait and see what happens – resonance etc - before perhaps putting in some stuff in.
S’nut
To Use sound deadening material ?
