Sponsored by: Innova
Replacing the Bose
Old Jul 29, 2003 | 05:16 PM
TJM's Avatar
TJM
Default Replacing the Bose
What is needed to change the BOSE UU8 to a UM6 style Delco radio?
Pretty much want to stay with the stock stuff. Lost most of my hearing to the US Navy and like the exhaust note better than most music.
Any pointers? Grills? Speakers sources? Wiring routing? Wiring nightmares?? Any Goofy wiring plugs that aren't available unless you know McLellan??
Have taken apart most of the car apart and put it back together, to fix other things, so other than buying a few screws and some shielded wire I figure it is just time???
TJM
Old Aug 3, 2003 | 11:29 AM
TJM's Avatar
TJM
Default Re: Replacing the Bose (TJM)
NCRS came up with the answers. All very borign fundemental stuff, I am sure.
For anyone else who is new, and not an expert on these sorts of things;
-- 4x6 up front
-- 6x9 rear
-- The Dash grills seem to be no longer available from GM? Odd.
-- The rear deck plate that supports the Bose also is the factory support for stock 6x9.
-- The Bose rear grills can remain, but are not stock UM6 parts. These are available and look like the Bose door grills
TJM
Old Aug 3, 2003 | 07:59 PM
bogus's Avatar
bogus
hm...
I would not bother.... for some reason, I think the internal harnessing is different... and that would be a problem.
you can pull out the bose, install aftermarket, and keep everything looking stock, sounding better, and returnable to orginal.
Old Aug 4, 2003 | 01:22 AM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Default Re: Replacing the Bose (bogus)
hm...
:iagree:
To Replacing the Bose
