Sponsored by: Innova
Help with AMP (adapter)
Old Aug 13, 2003 | 12:05 AM
sindows98's Avatar
sindows98
Default Help with AMP (adapter)
I have the stock bose head unit will I need any adapters to hook up my amp? If so what kind and were can I get it.
Old Aug 13, 2003 | 01:18 AM
2000Dream's Avatar
2000Dream
Default Re: Help with AMP (sindows98)
You can wire in rca connectors to output to the amps. You'll save quite a bit off the adapters that do the same thing. Here's the link to the tech tips that tell you how to do it. https://www.corvetteforum.com/techti...=120&TopicID=1
You'll want these connections:
"The following are the Bose head unit 4 channel pre-amp outputs
Signal CD/Radio Color code
LF out C4(9) TAN/BLK
RF out C4(10) LT GRN/BLK
LR out C4(11) BRN
RR out C4(12) DK BLU
Common C4(13) LT BLU, DO NOT USE FOR EXTERNAL POWER AMP
Shield C4(14) Bare wire
Ground C4(15) BLK"
99HT provided all this information.
As long as you can solder you'll be fine. I hooked up short female rca connectors to the head unit. Plugged in the male connectors to them and ran to amps. This way I can easily disconnect if I decide to go with aftermarket head unit.
Kris
Old Aug 13, 2003 | 01:42 AM
rockrz's Avatar
rockrz
Default Re: Help with AMP (2000Dream)
I made up a y-cable to do this, Used female rca's on one end, and put 3 push-on spade connectors on the other end. (1 for left, 1 for right, 1 for common return). I then used self-splicing connectors to 'tap' into the factory wires. My spade connectors push right on to these, so there was no soldering or cutting of wires in the dash.
Total cost: $6
Old Aug 13, 2003 | 01:55 AM
2000Dream's Avatar
2000Dream
:iagree:
This is a great method if you don't want to solder. I do it everyday so it was no big deal to cut the wires to me. IMHO soldering the wires is a much better connection.
Kris
[Modified by 2000Dream, 3:04 AM 8/13/2003]
To Help with AMP (adapter)
