Sponsored by: Innova
New mids or new components?
Old Aug 20, 2003 | 09:28 AM
MVP's Avatar
MVP
Default New mids or new components?
Well I think both of my mids are shot you can see my previous post here
Can I buy just mids? Or should I just buy some CDT's?
The Zeb has some limited edition Carbon Fiber High definition CDT's for $299 and 4 year warranty. How do these sound?
[Modified by MVP, 9:29 AM 8/20/2003]
Old Aug 20, 2003 | 11:15 AM
Kale's Avatar
Kale
Default Re: New mids or new components? (MVP)
It's pretty damn hard to kill a Focal Utopia speaker (Believe me, I've tried.) I'd test the speakers for continuity first...
Old Aug 20, 2003 | 12:26 PM
MVP's Avatar
MVP
Default Re: New mids or new components? (Kale)
My volt meter is also dead, so I am borrowing my cousin's tonght.
Exactly how did you try to kill a Utopia and WHY!
[Modified by MVP, 12:26 PM 8/20/2003]
Old Aug 20, 2003 | 01:12 PM
Kale's Avatar
Kale
Just playing with bass boost, test tones, and crossover settings. Do you know someone else with a stereo that can test them for you?
when testing a non mounted speaker, you want to run the gains ALL the way down and start the volume at 0, slowly raise it to see if you hear the sound.
Old Aug 20, 2003 | 01:50 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
What tweeters do you have now?
Let me know if you wanna sell them or split the new set.
:cheers:
Old Aug 21, 2003 | 08:58 AM
MVP's Avatar
MVP
There is no continuity :mad
Is there a way to fix speakers? :confused:
Old Aug 21, 2003 | 11:25 AM
Kale's Avatar
Kale
are they under warranty? im sure that Focal can fix them either way.. but I'd be worried you might toast them again. its unusual for one W speaker to go, but both?
Old Aug 21, 2003 | 11:50 AM
MVP's Avatar
MVP
They would be under warranty, but I didn't buy from an authorized dealer. Gotta call the guy I brought them from and see if he can help or call Focal directly and see what happens.
What do you think could have happened for them to "toast"? I have a very similar set up to yours (same HU and amps). My gains are set about half way. I had the utopia's crossed over at about 65hz, and I was about to change to up to 80hz this past weekend, but I guess I didn't get a chance for that.
Would water damage them? It does get wet in the C5 doors! There is a little rust spot on the inside of the hole of the magnet.
Also does the sub level on the HU control the sub-w out only?
THis sucks driving around with no music. This car is my daily driver.
[Modified by MVP, 11:52 AM 8/21/2003]
Old Aug 21, 2003 | 01:09 PM
Kale's Avatar
Kale
either they got so hot they burned, or it was mechanical damage. Neither of which should be an issue with that amp. Neither of which should really happen at the same time. When you say you tested for continuity..
did you use an ohmmeter set to 0-20 ohm and measure directly from the speaker terminals?
Water COULD damage them. I'd imagine my c4 would have been way worse for that though, and it wasnt an issue.
Did you buy them used?
yeah, the sub out is a sub volume control basically. 15 is nominal, then you can reduce it 15 steps.
[Modified by Kale, 10:10 AM 8/21/2003]
Old Aug 21, 2003 | 01:49 PM
MVP's Avatar
MVP
There was only one setting for resistance and yes I measured at the terminals. The speakers are out of the car right now.
Nope, New. at least i believed them to be. They looked new.
To New mids or new components?
