Sponsored by: Innova
3rd brake light is rattling
Old Aug 22, 2003 | 07:05 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default 3rd brake light is rattling
My 3rd brakelight is rattling under heavy bass.. any ideas???
Old Aug 23, 2003 | 08:13 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: 3rd brake light is rattling (ICULUKN-C5)
no one else is experiencing this problem?>???
:confused:
Old Aug 24, 2003 | 02:10 PM
Still_Single's Avatar
Still_Single
It's held in from the bottom by 2 screws. It's easy to get to by pulling a taillight. I'd start by making sure the screws are tight. If the screws are tight, then you could probably wrap it in Dynamat or equivalent on the inside and take out the vibration. Just a thought ...
Old Aug 25, 2003 | 08:08 AM
knewblewkorvette's Avatar
knewblewkorvette
I used to have the screws come out of my 3rd brake light from the bass in the back. I have to agree with the idea of Dynamat. Also use loc-tite or silicone on the screws.
Old Aug 25, 2003 | 11:01 AM
leolufse's Avatar
leolufse
Default Re: 3rd brake light is rattling (knewblewkorvette)
I had this problem with my licence plate. I used some strips of weather strip to isolate it from the bracket. Might work similarly for the third brake light.
Old Aug 25, 2003 | 05:18 PM
knewblewkorvette
Default Re: 3rd brake light is rattling (leolufse)
Good idea, I'll be trying that on my licence plate brackets. :thumbs:
Old Aug 26, 2003 | 02:46 AM
2000Dream's Avatar
2000Dream
I had the same problem. Sounded cheap from the outside. I took some of the "anti-vibration goop" that came with my speakers and put it on the top and bottom of the 3rd brake light. I put it up underneath so it can't be seen. You can get it in the gap around the edges pretty easily. I used the end of a tie wrap to push it in. No more vibration.
To 3rd brake light is rattling
