Sponsored by: Innova
C5 HVAC Controls... Single DIN?
Old Sep 13, 2003 | 03:22 PM
Tiger Shark's Avatar
Tiger Shark
Default C5 HVAC Controls... Single DIN?
Hi,
I want to drop my HVAC controls into the ash tray area, then put a single DIN HU into the area where the HVAC originally was. Will it be a perfect fit? (<- the HU) Or will I need to do some cutting? :confused: I haven't pulled it apart yet, so I'm not sure if there's anything behind the HVAC controls that would be in the way. The HU is 6-1/2” deep.
Thanks for the info! :cheers:
Anyone tried this?
[Modified by Tiger Shark, 8:43 PM 9/13/2003]
Old Sep 14, 2003 | 11:11 AM
ltnate's Avatar
ltnate
Default Re: C5 HVAC Controls... Single DIN? (Tiger Shark)
I just put a din sized EQ in the same place and moved my HVAC contols to the bottom. No issues at all except having to drill a couple of extra holes to mount the HVAC contol.
Old Sep 14, 2003 | 03:05 PM
Tiger Shark
Default Re: C5 HVAC Controls... Single DIN? (ltnate)
Hi ltnate. Thanks for the response!
Do you have a picture you could post or e-mail me of your finished installation? I'm curious to see how a single DIN sized unit looks in that spot.
Thanks!
:cheers:
Old Sep 15, 2003 | 03:00 AM
vrumvrum's Avatar
vrumvrum
I have a bunch of pictures posted in the root directory http://www.flamingpaperbag.com/radioinstall/
I can fix you up with a mounting plate that will bolt up to the air control mounting holes.
Old Sep 15, 2003 | 08:03 AM
MEATHOUSE's Avatar
MEATHOUSE
After you cut out the ash tray area, how do you secure the piece to the frame, I know there are 2 screws in that section holding the plastic trim piece on there? Do you just the one screw by the ignition???
Thanks, Justin :flag
Old Sep 15, 2003 | 01:38 PM
vrumvrum's Avatar
vrumvrum
Default Re: C5 HVAC Controls... Single DIN? (MEATHOUSE)
I just used the one by the ignition and the 2 screws under the ride control switch. There are a couple of snap tabs along the edges adn top that hold the unit in pretty securely. :thumbs:
Old Sep 15, 2003 | 09:15 PM
Tiger Shark
Default Re: C5 HVAC Controls... Single DIN? (vrumvrum)
Thanks vrumvrum! :cheers:
Old Sep 16, 2003 | 10:44 PM
ltnate's Avatar
ltnate
I sent you pics.
Old Sep 17, 2003 | 04:34 PM
Tiger Shark
Thanks!
To C5 HVAC Controls... Single DIN?
