Sponsored by: Innova
1990 headunit install question
Old Sep 13, 2003 | 05:29 PM
psuvette's Avatar
psuvette
Default 1990 headunit install question
Our crappy bose system needs to be replaced in out 1990. I've been searching around on the boards and came to the realization that a headunit installation may not be very easy or look the best because the dash bezel is about 3/16" of an inch too narrow.
I was hoping to buy a new pioneer headunit that plays mp3's to install into the dash. I believe it is the 7500MP unit.
Does anyone have any information concerning headunit installs in 90 corvettes? I would very much like to install this headunit but I am uncertain where I can get a mounting kit that would look great and not have a big gap around the outside of the headunit faceplate which shows off the mounting hardware.
Also, does anyone have any wiring information?
Thanks for your help everyone...I've installed a rather potent stereo in our other car, but it seems to me that theres some issues that I'd like to work out before I tear apart our vette.
Old Sep 14, 2003 | 12:37 PM
chaos on wheels's Avatar
chaos on wheels
Default Re: 1990 headunit install question (psuvette)
I have Pioneer's DEH-P7400MP and the indash 6-disc changer. I didn't have to cut the dash. The trim bezel around the faceplate of the 7400 snaps off and allows the face to fit through the dash opening from bahind.
I didn't use the DIN sleeve to install the deck. The deck has threaded holes on the side. I made custom sheet metal brackets which screw to the sides of the decks and mount them the same as the factory radio. It took a few tries to get the position right.
There is also a plastic piece in the back of the radio cavity which I had cut out for a previous install.
For power, I tapped into the wiring for the radio control box, above the passenger footwell. I'm not using the speaker outputs, just external amps, which get power directly from the battery.
