Which model? I was just about to buy the Hifonics zx8000 but, found a stray dog and took him to the vet, pet deposit, toys, etc so amp money gone. :D I'm still going to buy it, but will be a couple of weeks. I have heard really good things about Hifonics.
Re: Just ordered Hifonics 750watt amp... (ParkRat)
Hifonics Nemesis NX750D
Class D Design
1 Ohm Stable
750 Watts RMS Into a 1 Ohm Load!
New 20th Anniversary HiFonics Heat Sink
Variable Low-Pass Crossover
Variable Subsonic Filter
Variable Bass Boost at 45 Hz
Remote Bass Level Control Included
Amplifier Type: Mono
RMS Power: 175W x 1 @ 4 ohms
Bridged RMS Power: 400W x 1 @ 2 ohms
THD at Rated RMS Power: <0.08%
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 10-400 Hz
Channel Separation: >70 dB
Signal to Noise Ratio: >96 dB
Fuse Rating: 80 amps
The specs look good. I do have a couple of questions.
Where did you get it?
Does it have direct power connections?
Is you IDMAX 2ohm DVC to get the full 750 watts?
Are you going to match up another HiFonics for your components?
What about your ARC amps?
Under the seats :confused:
what year do you have? I don't think I can fit a pack of smokes under mine it is so tight.
Congrads on your new amp, remember to post pictures :)
Re: Just ordered Hifonics 750watt amp... (knewblewkorvette)
