Sponsored by: Innova
Battery to Amp Wiring
Old Oct 17, 2003 | 06:20 PM
FYNL4's Avatar
FYNL4
Default Battery to Amp Wiring
I know I saw a post on this recently but I can't seem to find it. I have a 2002 'vert and I want to get power to my sub amp in the trunk. What is the easiest way to route the Positive Lead from the battery back to the trunk? Is there a way of routing it so that I don't have to cut a hole in the firewall?
Old Oct 17, 2003 | 07:50 PM
ltnate's Avatar
ltnate
Default Re: Battery to Amp Wiring (FYNL4)
If you remove your battery, you'll see there is already a grommet to run your power cable. I used this to run my cable to the amp.
Old Oct 17, 2003 | 08:00 PM
FYNL4's Avatar
FYNL4
Default Re: Battery to Amp Wiring (ltnate)
Thanks for the reply. I'll give it a try.......
To Battery to Amp Wiring
