Sponsored by: Innova
Broken 12 disk cd changer.
Old Oct 25, 2003 | 10:21 AM
PeterK's Avatar
PeterK
St. Jude Donor '12
2012 Election Contest Winner
Default Broken 12 disk cd changer.
The CD changer I recently purchased appears to be non-functional.
When connected to a harness - it makes no noise. When the door is opened - the lights come on: one white, in front, one red inside. When I close the door - there no mechanical motion again.
The magazine is now stuck in there.
Seller said that CD changer worked great b/f he shipped.
What do you think might have gone wrong?
Are these easy to repair? If seller said that it was working just fine - I don't see what could have happened during shipment - the box was intact.
[Modified by PeterK, 9:24 AM 10/25/2003]
Old Oct 25, 2003 | 01:24 PM
knewblewkorvette's Avatar
knewblewkorvette
Default Re: Broken 12 disk cd changer. (PeterK)
Big question first. Did he ship it with the magazine inside the changer?
Old Oct 25, 2003 | 01:38 PM
PeterK's Avatar
PeterK
St. Jude Donor '12
Default Re: Broken 12 disk cd changer. (knewblewkorvette)
No they were separate.
Old Oct 25, 2003 | 04:08 PM
knewblewkorvette
That is a good thing.
Do you have the install manual for it? If not, I could fax it to you.
Old Oct 25, 2003 | 04:50 PM
builtfspd2's Avatar
builtfspd2
i had the same problem. i am a newbie with a new used vette. after you loaded the magazine and put it in the cd changer, does it make noise and go thru a loading process? i am told you have to wait until it goes thru the cycle before you can turn on the ignition. once i did that, my changer is working with no problems and the magazine pops out. i pried mine out carefully after it was stuck but it hasnt stuck since then.
[Modified by builtfspd2, 4:50 PM 10/25/2003]
Old Oct 25, 2003 | 05:46 PM
ltnate's Avatar
ltnate
Default Re: Broken 12 disk cd changer. (builtfspd2)
Yeah I'm the guy who sold him the system. I knew it had to be something crazy going on. That entire system worked perfect an hour before I shipped it; I tested everything. Hope this works for you Peter.
Old Oct 25, 2003 | 06:09 PM
PeterK's Avatar
PeterK
St. Jude Donor '12
Well, that seems to be a problem - the changer just doesn't do a thing. I don't hear anything going on - it just seats there.
I've tried to slightly push the magazine in, I've tried to pull it out to no avail.
Old Oct 27, 2003 | 07:11 PM
PeterK's Avatar
PeterK
St. Jude Donor '12
anyone has ane exp. repairing these?
Old Oct 27, 2003 | 07:27 PM
ltnate's Avatar
ltnate
I'm very interested in what was wrong with the changer.
Old Oct 27, 2003 | 07:58 PM
PeterK's Avatar
PeterK
St. Jude Donor '12
Default Re: Broken 12 disk cd changer. (ltnate)
Me too, but they won't even touch it till wends. :banghead:
Old Oct 27, 2003 | 08:33 PM
ltnate's Avatar
ltnate
Well I still think it had something to do with shipping. Dropped box or something regardless of the condition of the box it still could've been dropped.
Old Oct 28, 2003 | 12:08 PM
PeterK's Avatar
PeterK
St. Jude Donor '12
I'm kind of afraid that that might be true. They dropped it flat and shook the bejesus out of it.
To Broken 12 disk cd changer.
