Sponsored by: Innova
disconnect battery
Old Nov 12, 2003 | 03:27 PM
wcj's Avatar
wcj
Default disconnect battery
After disconnecting battery how do you unlock the radio. also how do you find the unlock codes prior to disconnecting the battery??? the car is going into an indoor show in three weeks and the battery has to be disconnected. its a 97 C-5. Thanks ahead of time. WCJ :party:
Old Nov 12, 2003 | 03:28 PM
bogus's Avatar
bogus
Default Re: disconnect battery (wcj)
did you buy the car new? If so, check your owners packet. There should be a card in their with the code.
if not, the dealer should be able, via the VIN, give you the code.
Old Nov 12, 2003 | 05:23 PM
Nelson V.'s Avatar
Nelson V.
Default Re: disconnect battery (bogus)
If you haven't yet disconnected the battery and the Theft Lock code is ENABLED, you should be able to see the code beforehand. The procedure is in the manual.
If the Theft Lock code is not ENABLED, you pick the code.
If you have already disconnected the battery, then I'm not sure.
To disconnect battery
