Sponsored by: Innova
What a rough decision...
Old Dec 17, 2003 | 11:22 AM
Kale's Avatar
Kale
Default What a rough decision...
Ive had my MAX sealed... and I've had it ported..
Sealed >
Somewhat flat response, excellent midbass properties (for a subwoofer)
Ported >
Incredible low end. Low low drums nearly kick you out of the seat. Much louder than sealed, much harder to locate in the vehicle. But the excellent "midbass" properties are all but gone. It's not a huge difference, but it helps in definition of sound. The SQ out of ported and sealed is identical but for this difference here.
hmn..
Old Dec 17, 2003 | 11:28 AM
leolufse's Avatar
leolufse
Default Re: What a rough decision... (Kale)
How about building a larger sealed box? It should increase the low end response while maintaining "midbass" and SQ. You'll also get more efficiency from the same wattage.
Old Dec 17, 2003 | 11:35 AM
Kale's Avatar
Kale
Default Re: What a rough decision... (leolufse)
I've thought about it. Right now the box is at ID's spec. 1.3 net
I'm going to invert mount the sub and see what happens. That will make the box 1.4x net.
unfortunately my midbass comes from 5.25's... so the mids can't round out the sub all that well.
[Modified by Kale, 8:37 AM 12/17/2003]
Old Dec 17, 2003 | 06:10 PM
EatRice's Avatar
EatRice
What do you have the sub and 5.25s xover at?
Old Dec 17, 2003 | 06:34 PM
Kale's Avatar
Kale
Default Re: What a rough decision... (EatRice)
mids 80 12db/oct
sub 80 24db/oct
Hmn,... MAYBE a passive radiator?
Old Dec 17, 2003 | 07:21 PM
EatRice's Avatar
EatRice
why would you want to use a passive radiator?
Old Dec 17, 2003 | 07:29 PM
Kale's Avatar
Kale
Honestly? For the unique-ness of it in car audio.
im going to run my sealed box again tonight and see how i like it
i never ran sealed @ 1000 watts. only ported @ 1000.
Old Dec 18, 2003 | 07:59 PM
knewblewkorvette's Avatar
knewblewkorvette
using a inductor/cap to x-over the sub is a bad idea, it would be added weight because when we are talking about 1000 watts, that would be a LARGE coil. It will consume wattage. Use an active crossover in the amp or before the amp. No wasted wattage :)
To What a rough decision...
