Sponsored by: Innova
New box finished...:)
Old Dec 31, 2003 | 02:18 AM
TheWacoKid's Avatar
TheWacoKid
Cruise-In II Veteran
Cruise-In III Veteran
Default New box finished...:)
Well...my new sub box is finished, 5.6 cubes sealed for 2 JBL gt1281 subs...Qtc of .83
Switched from 2.5 cubes sealed with a Qtc of 1.15
The amp is 450 watts rms at 4 ohms.
Before, the bass was strong in the upper ranges, but not very defined and very muddy in the sub-60 hz region. Now, the bass is just as strong in the higher octaves(from 80 to 160) but is much more defined and punchy, and the lower octaves are simply monstruous. Every single drum/cello/whatever that is below 80 hz or so is so powerful and tight it blurs your vision.
The Pirates of the Carribean soundtrack used to be just a rumbling in the background because of all the deep orchestral drums. Now, each drum can be picked out from the cellos, and each drum hit sounds like you are sitting right next to the drum. The fricking steering wheel was shaking, my clothes were shaking...it was the loudest, lowest bass I have ever felt! The thing that suprised me though was how musical it was...it blended perfectly with my Boston components up front(~150 rms per side, but gains pretty low).
I then proceeded to play a sine sweep from 1000 hz to 5 hz...what a mistake! It was so loud that my windows were moving about 1/2 inch in either direction, the steering wheel was hard to hold on to, and it played strongly till the end of the track(dropped off at about 10 hz). I could not see straight. It was simply amazing the difference from the old box to the new.
The only downside is that the box cannot be removed from the car without removing the top panel, since it was too big to clear the rear window with the top panel on. However, I lost only 4 inches of depth in the trunk because my old box was trapezoidal.
I can't imagine how these subs would sound in a optimal box with a Qtc of .707, but I will probobly never hear them in a box like that since they require 4.8 cubes each for that alignment!
Anyway, as everyone can probobly tell, I am overjoyed by my newfound sound quality, along with the very increased spl. :cheers: :cheers: :cheers:
This is me ---> :D :D :D
When I can find my camera I will take some pics tommorrow.
[Modified by TheWacoKid, 2:20 AM 12/31/2003]
Old Dec 31, 2003 | 02:23 AM
TheWacoKid's Avatar
TheWacoKid
Default Re: New box finished...:) (TheWacoKid)
Now that I think about it, does anyone know what the cabin gain in a old w-body GM car is?
Car in question is a 1990 Chevy Lumina coupe- the thing must have awesome transfer function gains way low for my subs to hit 10 hz pretty hard.
:D :D :D I'm so glad I made this box. :D :D :D
Old Dec 31, 2003 | 09:42 AM
EatRice's Avatar
EatRice
How do you know it is hitting 10hz? You can not hear 10hz?
Old Dec 31, 2003 | 09:46 AM
leolufse's Avatar
leolufse
Default Re: New box finished...:) (EatRice)
I'm looking forward to the pics. 5.6 ft^3 is a box the size of a small bathroom :rofl:
Old Dec 31, 2003 | 11:25 AM
Metal Wulf's Avatar
Metal Wulf
Default Re: New box finished...:) (leolufse)
:thumbs:
Old Dec 31, 2003 | 03:06 PM
TheWacoKid's Avatar
TheWacoKid
Who cares if I can hear it? I can feel it fine. :D
BTW the track announced the transitions between frequencies(thats how I know it was 10 hz or so). :cheers:
To New box finished...:)
By Michael S. Palmer | 2026-06-03 09:39:05
