Sponsored by: Innova
C5: Line output converter help!!!
Old Jan 11, 2004 | 01:32 AM
thebadbat's Avatar
thebadbat
Default C5: Line output converter help!!!
Hey guys,
I am installing a custom enclosure, one 12" MTX 8000 sub, and a Kicker KX400.1 amplifier. I have all of the wiring ran, except I believe I am having trouble with the Line-output converter. I could have possibly wired it wrong (stock Bose head unit on a 2003 Z06) It is grounded correctly, all wires are correct, because amp has power, but I have no signal to the subwoofer....
Any reccomendations? I installed the line output converter behind the head unit, and spliced it into place.. Maybe I used the wrong wires for the connection? Should I remove tyhe line output converter, and reinstll in behind the deck, like at one of the rear speakers? What did I do wrong?
Thanks in advance for all of the help! :cheers:
TJ
Old Jan 11, 2004 | 02:44 AM
Grzldvt's Avatar
Grzldvt
Default Re: C5: Line output converter help!!! (thebadbat)
How did you splice from the HU to the line converter? If you used what I call the "in line" connectors, it is pretty easy to use a size that has a slot too large, and it will not even cut through the insulation. The output wiring from the HU is pretty thin gauge and it takes a very small slot or connector to make sure you have a clean connection.
Second what wires did you use? They should be from the C4 connector and you can use the LT Grn/Blk(RF) Tan/Blk(LF), Dk Blue(RR) or Dkn Brn(LR) for Positive and use the unshielded(wrapped in clear) for negative.
My 98 has full range though all 4 wires coming off teh C4 connector. I just installed an amp and sub tonight and experimented with both front and rear RCA connections to make sure I had everything hooked up correctly and there was no difference in the sound at all.
Hope that helps.
Old Jan 11, 2004 | 02:50 AM
thebadbat's Avatar
thebadbat
Default Re: C5: Line output converter help!!! (Grzldvt)
Steve, you could be right, because the wires you stated are the ones that I am splicing through.... Maybe the slots ARE too big, guess I will look for some smaller ones for the smaller guage, to make sure the cut is actually going through, and touching the wire...
Thanks for your help bro, I appreciate it! :cheers:
TJ
Old Jan 11, 2004 | 03:35 AM
Grzldvt's Avatar
Grzldvt
I should have mentioned I got mine at radio Shack for 18-22 gauge wire. They are red versus the always to be found blue ones.
To C5: Line output converter help!!!
