Sponsored by: Innova
C5 Speaker Wire Installation Question
Old Jan 14, 2004 | 10:43 PM
Racer_X's Avatar
Racer_X
Default C5 Speaker Wire Installation Question
I'm planning on installing a new head unit in my 2003, and based on many recommendations here, I'm strongly considering installing new speaker wiring and speakers at the same time. Before I go forward with this, I would like to know how difficult it is to actually do the new wiring installation. Is the removal of various panels in the door and along the floor, and the threading of the wire behind these panels, fairly straightforward? Time-consuming? Any suggestions or tips? I've never done rewiring before, so I'd like to make sure I'm not biting off more than I can chew! Thanks.
Old Jan 14, 2004 | 11:52 PM
Grzldvt's Avatar
Grzldvt
Default Re: C5 Speaker Wire Installation Question (Racer_X)
It is actually pretty easy. The front kick panels can be pried off. They have the plastic removable rivets. The door sills just lift right up and the rear carpeting, is easily lifted up and put back in place.
here is a link for the door panels. http://www.vetteessentials.com/instr...or_handle.html
Look for a small plastic cover in the upper front area of the drivers/passenger sides, roughly where the door meets the body. These are openings that will allow you to thread the speaker wire though the body to the door. These plastic covers, can be pried out and popped back in.
Then check this post for what I did to eliminate any rattles http://forums.corvetteforum.com/zerothread?id=726729
Old Jan 15, 2004 | 11:54 AM
leolufse's Avatar
leolufse
Default Re: C5 Speaker Wire Installation Question (Grzldvt)
:withstupid:
The C5 is one of the easiest cars I've every worked on to run the wiring into the doors. Once you pop that panel off, you can stick your whole hand inside the rubber boot that is between the door and the A pillar.
Old Jan 15, 2004 | 04:10 PM
Racer_X's Avatar
Racer_X
Default Re: C5 Speaker Wire Installation Question (leolufse)
Thanks for the replys, guys, this helps a lot. But what about for the rear speakers? I assume pulling off the door sill trim will be very straightforward, but what about getting the wire up the rear piller to the speaker? A quick glance makes me think that the piller covering doesn't come off easily, so what's the best way to thread the wiring those last few inches? I'm thinking I can tie string to the end of the current wire, pull the wire down from the bottom, tie the new wire to the string, then pull it back up. Assuming the current speaker wire is loose in the real piller, it should work. Thoughts?
Old Jan 15, 2004 | 04:29 PM
leolufse's Avatar
leolufse
I've never pulled off the C pillar trim on coupe, only on FRC and Z06. But it cant be that much different. Just have to pull out the seat belt shoulder bolt and the rest of the panel is just snapped in. There are no hidden screws. On the FRC you have to remove the rear window trim first, then the C pillar trim. Just slide your fingers in from the top along the headliner and pull towards you gently.
Old Jan 16, 2004 | 01:13 AM
Grzldvt's Avatar
Grzldvt
I left my rears alone, but I just pulled my speaker cover off and you can slip the rear wires under the carpet and slide the wire in right under the trim. Looks very simple to me.
Old Jan 19, 2004 | 01:19 AM
FreddyG's Avatar
FreddyG
Taking the door panels off was pretty straight forward, but how in the heck do I get the wire into the car. I took the accordian boot off that goes between the body and the door, but where does the wire go to once it's fed into the car. I have a panel inside the car, underneath the side panel that has bar coding on it. Do I have to take this off? Do you guys have any pics of this panel? I'm pulling what's left of my hair out! Thanks
To C5 Speaker Wire Installation Question
