Sponsored by: Innova
Installing two 10s
Old Jan 21, 2004 | 11:36 AM
cglasse's Avatar
cglasse
Default Installing two 10s
Hey all, I was looking for some advice on how to put 2 10s in the trunk of my pace car. I wanted to do something like a stealth box, but with some pretty fiberglass accents to match the exterior. So the subs sit in the wells and leaves the trunk still "open." Does anyone have pics of something like this? Advice, comments, suggestions... anything?
Old Jan 21, 2004 | 02:20 PM
CarbonTuning's Avatar
CarbonTuning
Default Re: Installing two 10s (cglasse)
Here is a pic of my install. Its a fiberglass enclosure in the spare tire hole. The top of the box is below the floor which allows the cover to be flush mounted. I have Soundstrem Tarantula amps so I suggested to my installer that he made a cover that matched. I was pleased with the results. I also have a amp rack finished w/ a painted top to match the exterior of my car, it looks pretty nice, though I dont have pics of it yet.
Old Jan 21, 2004 | 05:12 PM
adeak1's Avatar
adeak1
Look here, they make a dual 10" stealth Box for center compartment. http://www.subthump.com/vette.htm
Andrew :party:
[Modified by adeak1, 6:20 PM 1/21/2004]
Old Jan 21, 2004 | 05:45 PM
knewblewkorvette's Avatar
knewblewkorvette
here is some pics of matching fiberglass
Old Jan 21, 2004 | 09:43 PM
cglasse's Avatar
cglasse
Default Re: Installing two 10s (knewblewkorvette)
Thanks guys! I hope more people post pics... this is really helping. :thumbs:
Old Jan 22, 2004 | 01:29 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Forum member Mike76002 makes cool sub boxes for dual 10's. I should have my dual 10 box here tomorrow. It fits in the center compartment and then you can put your stock cover on. This is wood, I know you said fiberglass but I thought I would mention this. I checked on a custom fiberglass enclosure for mine that would of had plexi glass with purple neons under it with 2 12" Kove armageddon subs.That was going to be around $1800. So I decided to go Mikes way and just let my 2 800 watt purple neon Splash amps do the glowing!! :seeya
Old Jan 22, 2004 | 01:54 PM
cglasse's Avatar
cglasse
Default Re: Installing two 10s (J's 1998 Pace Car)
I'll consider anything at the moment... and I'd love to see some pics of what you are doing!
Old Jan 22, 2004 | 02:08 PM
85 Stalker's Avatar
85 Stalker
Can you post some pictures ???? :cheers:
Old Jan 22, 2004 | 03:38 PM
NVTHIS's Avatar
NVTHIS
Default Re: Installing two 10s (85 Stalker)
I'll try to get pics tomorrow, when I hopefuuly get the box. The two amps are mounted right behind each seat with a Hart Hex 80 3 way crossover sitting right behind the waterfall. The 1 farad cap. it located down from the crossover. I just got these sitting in here right now. I will be getting an amp rack made to hide the wiring and to recess the cap. and crossover. I may put the cap. on one side of the corners in the trunk area and be recessed and so forth with the crossover on the other side.The two amps look awesome at night either looking through the front of the car or with the trunk open, such as at car shows. The amps are made by Power Acoustik and they really are good amps. They are called Splash Neon 802. I have a 1102 in my truck(1100 watts). These are discontinued now, but I found a matching one on ebay not too long ago that matched an 802 that I had. I'll try to get some pics posted later of what they look like at night. More pics will follow probably tomorrow!!
Old Jan 22, 2004 | 03:53 PM
Kale's Avatar
Kale
Default Re: Installing two 10s (CarbonTuning)
Why not a single super 12 instead? Here's a pic of an IDMAX 12 compared to one of the subs he has under that grill:
Old Jan 22, 2004 | 04:19 PM
cglasse's Avatar
cglasse
Default Re: Installing two 10s (Kale)
I've already got 2 eclipse 10s from my last car that have been sitting in the garage waiting to be used. Also have the eclipse amp.
Old Jan 22, 2004 | 04:26 PM
Kale's Avatar
Kale
Are they the groovy metal ones that go Pang instead of Bang?
Old Jan 22, 2004 | 05:00 PM
NVTHIS's Avatar
NVTHIS
Here are the amps at night!! I'll see if I can find more pics!! This pic isn't big enough , let me resize it!!
[Modified by J's 1998 Pace Car, 4:02 PM 1/22/2004]
Old Jan 22, 2004 | 05:12 PM
85 Stalker's Avatar
85 Stalker
Bling! :cool:
Old Jan 22, 2004 | 05:53 PM
cglasse's Avatar
cglasse
I wish... I couldn't afford the metal ones... I'm just a college student!
I totaly want amps that glow like that!
[Modified by cglasse, 4:55 PM 1/22/2004]
Old Jan 22, 2004 | 05:58 PM
Kale's Avatar
Kale
get some neon tubing frmo Wal-mart for a cuople bucks and hide it in the amp box near the amps.
I have an amp that glows... but being under my seat, tehblue footwell at night looks pretty funny
Old Jan 22, 2004 | 09:37 PM
NVTHIS's Avatar
NVTHIS
Heres a little bigger pic!!
[Modified by J's 1998 Pace Car, 8:39 PM 1/22/2004]
To Installing two 10s
Old Jan 23, 2004 | 03:56 AM
CarbonTuning
I actually just got back from having the two IDQ 10's swapped out for a 10w7. :D
Old Jan 23, 2004 | 01:34 PM
Kale's Avatar
Kale
Is the 10w7 much louder?
Old Jan 23, 2004 | 02:32 PM
CarbonTuning
I havent had a chance to thoroughly test it, mostly b/c my amp keeps going into protection mode (it did this w/ the IDQs as well) so I have to take it back to upgrade the big-3. But the SQ on the w7 and the IDQs is very similar. But Im going to hold off from saying which sounds better until I get a chance to play w/ the w7 a bit more.
